How can I check-out VE 1.3? [message #138007] |
Fri, 08 June 2007 14:39 |
Originally posted by: sergiosamayoa.icon.com.gt
I want to use ve in Europa and read that someone (please fortgive me
because I dont remember his name) checked-in 1.3.0 which is basically a
1.2.x modified to allow run in Europa.
Also, where can I get into ve internals?
I have a little spare time and may be I can contribute to ve.
Regards.
Re: How can I check-out VE 1.3? [message #138133 is a reply to message #138007] |
Sat, 16 June 2007 12:25 |
Originally posted by: akarypid.yahoo.gr
I've just managed to partially compile VE with Europa.
You need to set up two CVS repositories and check out some packages:
(see http://wiki.eclipse.org/index.php/CVS_Howto#Anonymous_CVS)
1) /cvsroot/webtools
org.eclipse.jem
org.eclipse.jem.beaninfo
2) /cvsroot/tools
org.eclipse.ve
org.eclipse.ve.cde
org.eclipse.ve.java.core
org.eclipse.ve.propertysheet
org.eclipse.ve.jfc (if you need Swing/AWT)
org.eclipse.ve.swt (if you need SWT/RCP)
> Regards.
Re: How can I check-out VE 1.3? [message #138140 is a reply to message #138133] |
Sat, 16 June 2007 12:26 |
What would you like to work on with VE? I'm also looking into it these days.
> org.eclipse.jem
> 2) /cvsroot/tools
> org.eclipse.ve
> org.eclipse.ve.cde
>> Regards.
Re: How can I check-out VE 1.3? [message #138146 is a reply to message #138140] |
Sat, 16 June 2007 13:50 |
> these days.
Well, first make it work on Europa then:
- Undertand the whole concept.
- Use the JFace components (those used by Eclipse editors).
- Binding.
Regards.
Re: How can I check-out VE 1.3? [message #616110 is a reply to message #138140] |
> these days.
- Binding.
Regards.
FUDForum. Page generated in 0.03827 seconds
