Home » Archived » BIRT » Cannot select data for chart
Cannot select data for chart [message #137966] Thu, 02 March 2006 06:25
Originally posted by: attacus.narod.ru
------=_NextPart_000_0059_01C63E05.2E092E30
Content-Type: text/plain;
charset="koi8-r"
Could you explain me how to resolve the issue I found or refer to =
mailing list where to ask?
I have installed Windows XP SPII, JDK 1.4.2, Eclipse SDK Version: 3.1.1 =
(Build id: M20050929-0840) and BIRT 2.0.1.
I do the following:
1. I create a Scripted Data Source and corresponding Data Set to supply =
the data for report.=20
2. Then drag a table to layout area. Bind it to data set.
3. See preview. The table is filled in. All is OK.
4. Go to the layout again and drag a chart to apply the same data. The =
screen "New Chart" appears.=20
5. Then push "Select Data". No data in "Data Preview" grid.
6. If I select "Use Data Set" instead of "Use Report Data", the error =
window appears:
"save in error
C:\Documents and Settings\Nickolai\Local =
Settings\Temp\BirtDataCache\session_0\metaData.data (Cannot find a =
file)"
at:
org.eclipse.birt.data.engine.executor.dscache.DataSetResultC ache$LoadUtil=
..init(DataSetResultCache.java:448)
..loadResultClass(DataSetResultCache.java:421)
org.eclipse.birt.data.engine.executor.dscache.DataSetResultC ache.loadResu=
ltClass(DataSetResultCache.java:237)
org.eclipse.birt.data.engine.executor.dscache.DataSetResultC ache.getResul=
tClass(DataSetResultCache.java:170)
org.eclipse.birt.data.engine.executor.dscache.CandidateQuery .getResultCla=
ss(CandidateQuery.java:34)
org.eclipse.birt.data.engine.impl.PreparedQuery$Executor.get ResultMetaDat=
a(PreparedQuery.java:693)
org.eclipse.birt.data.engine.impl.QueryResults.getResultMeta Data(QueryRes=
ults.java:136)
org.eclipse.birt.report.designer.internal.ui.util.DataSetMan ager.getCache=
MetaData(DataSetManager.java:934)
MetaData(DataSetManager.java:907)
org.eclipse.birt.chart.reportitem.ReportDataServiceProvider. getPreviewHea=
derModel(ReportDataServiceProvider.java:96)
der(ReportDataServiceProvider.java:78)
org.eclipse.birt.chart.ui.swt.wizard.TaskSelectData.switchDa taTable(TaskS=
electData.java:397)
org.eclipse.birt.chart.ui.swt.wizard.TaskSelectData.switchDa taSet(TaskSel=
ectData.java:461)
org.eclipse.birt.chart.ui.swt.wizard.TaskSelectData.widgetSe lected(TaskSe=
lectData.java:518)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
org.eclipse.birt.core.ui.frameworks.taskwizard.WizardBase.op en(WizardBase=
..java:219)
org.eclipse.birt.chart.ui.swt.wizard.ChartWizard.open(ChartW izard.java:17=
5)
org.eclipse.birt.chart.reportitem.ChartReportItemBuilderImpl .open(ChartRe=
portItemBuilderImpl.java:207)
org.eclipse.birt.report.designer.internal.ui.editors.schemat ic.extensions=
..ExtendedElementToolExtends.preHandleMouseUp(ExtendedElemen tToolExtends.j=
ava:55)
org.eclipse.birt.report.designer.internal.ui.palette.ReportT emplateTransf=
erDropTargetListener.handleDrop(ReportTemplateTransferDropTa rgetListener.=
java:136)
org.eclipse.gef.dnd.AbstractTransferDropTargetListener.drop( AbstractTrans=
ferDropTargetListener.java:171)
org.eclipse.jface.util.DelegatingDropAdapter$3.run(Delegatin gDropAdapter.=
java:211)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.j=
ava:1044)
org.eclipse.core.runtime.Platform.run(Platform.java:783)
org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
org.eclipse.jface.util.DelegatingDropAdapter.drop(Delegating DropAdapter.j=
ava:209)
org.eclipse.swt.dnd.DNDListener.handleEvent(DNDListener.java :65)
org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:852)
org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:6 60)
org.eclipse.swt.dnd.DropTarget.notifyListeners(DropTarget.ja va:480)
org.eclipse.swt.dnd.DropTarget.Drop(DropTarget.java:405)
org.eclipse.swt.dnd.DropTarget.access$7(DropTarget.java:350)
org.eclipse.swt.dnd.DropTarget$3.method6(DropTarget.java:236 )
org.eclipse.swt.internal.ole.win32.COMObject.callback6(COMOb ject.java:117=
org.eclipse.swt.internal.ole.win32.COM.DoDragDrop(Native Method)
org.eclipse.swt.dnd.DragSource.drag(DragSource.java:277)
org.eclipse.swt.dnd.DragSource.access$0(DragSource.java:267)
org.eclipse.swt.dnd.DragSource$1.handleEvent(DragSource.java :161)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:36=
7)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivat=
or.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:3=
76)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:1=
63)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
java.lang.reflect.Method.invoke(Unknown Source)
org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
org.eclipse.core.launcher.Main.basicRun(Main.java:278)
org.eclipse.core.launcher.Main.run(Main.java:973)
org.eclipse.core.launcher.Main.main(Main.java:948)
Content-Type: text/html;
charset="koi8-r"
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; charset=3Dkoi8-r">
<META content=3D"MSHTML 6.00.2900.2802" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Hello,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Could you explain me how to resolve the =
issue I=20
found or refer to mailing list where to ask?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>I have installed Windows XP SPII, JDK =
1.4.2,=20
Eclipse SDK Version: 3.1.1 (Build id: M20050929-0840) and BIRT=20
2.0.1.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I do the following:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>1. I&nbsp;create a Scripted Data Source =
and=20
corresponding Data Set to supply the data for report. </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>2. Then drag a table to layout area. =
Bind it to=20
data set.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>3. See preview. The table is filled in. =
All is=20
OK.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>4. Go to&nbsp;the layout again and drag =
a chart to=20
apply the same data. The screen "New Chart"</FONT>&nbsp;<FONT =
face=3DArial=20
size=3D2>appears. </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>5. Then push "Select Data". <FONT =
color=3D#ff0000>No=20
data in "Data Preview" grid.</FONT></FONT></DIV>
<DIV><FONT face=3DArial color=3D#ff0000 size=3D2><FONT =
color=3D#000000>6. </FONT><FONT=20
color=3D#ff0000>If I select "Use Data Set" instead of "Use Report Data", =
the error=20
window appears:</FONT></FONT></DIV>
<DIV><FONT face=3DArial color=3D#ff0000 size=3D2>"save in =
error<BR>C:\Documents and=20
Settings\Temp\BirtDataCache\session_0\metaData.data=20
(Cannot find a file)"</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>at:</FONT></DIV>
<DIV><FONT face=3DArial=20
size=3D2> org.eclipse.birt.data.engine.executor.dscache.DataSetResultC ache=
$LoadUtil.init(DataSetResultCache.java:448)<BR>org.eclipse.birt.data.engi=
ne.executor.dscache.DataSetResultCache$LoadUtil.loadResultCl ass(DataSetRe=
sultCache.java:421)<BR>org.eclipse.birt.data.engine.executor.dscache.Data=
SetResultCache.loadResultClass(DataSetResultCache.java:237)<BR >org.eclips=
e.birt.data.engine.executor.dscache.DataSetResultCache.getRe sultClass(Dat=
aSetResultCache.java:170)<BR>org.eclipse.birt.data.engine.executor.dscach=
e.CandidateQuery.getResultClass(CandidateQuery.java:34)<BR>org.eclipse.bi=
rt.data.engine.impl.PreparedQuery$Executor.getResultMetaData (PreparedQuer=
y.java:693)<BR>org.eclipse.birt.data.engine.impl.QueryResults.getResultMe=
taData(QueryResults.java:136)<BR>org.eclipse.birt.report.designer.interna=
l.ui.util.DataSetManager.getCacheMetaData(DataSetManager.jav a:934) <BR>org=
..eclipse.birt.report.designer.internal.ui.util.DataSetManag er.getCacheMet=
aData(DataSetManager.java:907)<BR>org.eclipse.birt.chart.reportitem.Repor=
tDataServiceProvider.getPreviewHeaderModel(ReportDataService Provider.java=
:96)<BR> org.eclipse.birt.chart.reportitem.ReportDataServiceProvider. getPr=
eviewHeader(ReportDataServiceProvider.java:78)<BR>org.eclipse.birt.chart.=
ui.swt.wizard.TaskSelectData.switchDataTable(TaskSelectData. java:397) <BR>=
ectData.java:461)<BR>org.eclipse.birt.chart.ui.swt.wizard.TaskSelectData.=
widgetSelected(TaskSelectData.java:518)<BR>org.eclipse.swt.widgets.TypedL=
istener.handleEvent(TypedListener.java:90)<BR>org.eclipse.swt.widgets.Eve=
ntTable.sendEvent(EventTable.java:66)<BR>org.eclipse.swt.widgets.Widget.s=
endEvent(Widget.java:843)<BR>org.eclipse.swt.widgets.Display.runDeferredE=
vents(Display.java:3080)<BR>org.eclipse.swt.widgets.Display.readAndDispat=
ch(Display.java:2713)<BR>org.eclipse.birt.core.ui.frameworks.taskwizard.W=
izardBase.open(WizardBase.java:219)<BR>org.eclipse.birt.chart.ui.swt.wiza=
rd.ChartWizard.open(ChartWizard.java:175)<BR>org.eclipse.birt.chart.repor=
titem.ChartReportItemBuilderImpl.open(ChartReportItemBuilder Impl.java:207=
)<BR> org.eclipse.birt.report.designer.internal.ui.editors.schemat ic.exten=
sions.ExtendedElementToolExtends.preHandleMouseUp(ExtendedEl ementToolExte=
nds.java:55)<BR>org.eclipse.birt.report.designer.internal.ui.palette.Repo=
rtTemplateTransferDropTargetListener.handleDrop(ReportTempla teTransferDro=
pTargetListener.java:136)<BR>org.eclipse.gef.dnd.AbstractTransferDropTarg=
etListener.drop(AbstractTransferDropTargetListener.java:171) <BR>org.eclip=
se.jface.util.DelegatingDropAdapter$3.run(DelegatingDropAdap ter.java:211)=
<BR> org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatfo=
rm.java:1044)<BR>org.eclipse.core.runtime.Platform.run(Platform.java:783)=
<BR>org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44) <BR>org.ecl=
ipse.jface.util.SafeRunnable.run(SafeRunnable.java:148)<BR>org.eclipse.jf=
ace.util.DelegatingDropAdapter.drop(DelegatingDropAdapter.ja va:209) <BR>or=
g.eclipse.swt.dnd.DNDListener.handleEvent(DNDListener.java:6 5) <BR>org.ecl=
ipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)<BR >org.eclipse.=
swt.widgets.Widget.sendEvent(Widget.java:843)<BR>org.eclipse.swt.widgets.=
Widget.sendEvent(Widget.java:867)<BR>org.eclipse.swt.widgets.Widget.sendE=
vent(Widget.java:852)<BR>org.eclipse.swt.widgets.Widget.notifyListeners(W=
idget.java:660)<BR>org.eclipse.swt.dnd.DropTarget.notifyListeners(DropTar=
get.java:480)<BR>org.eclipse.swt.dnd.DropTarget.Drop(DropTarget.java:405)=
<BR> org.eclipse.swt.dnd.DropTarget.access$7(DropTarget.java:350) <BR>org.e=
clipse.swt.dnd.DropTarget$3.method6(DropTarget.java:236)<BR >org.eclipse.s=
wt.internal.ole.win32.COMObject.callback6(COMObject.java:117 ) <BR>org.ecli=
pse.swt.internal.ole.win32.COM.DoDragDrop(Native=20
Method)<BR>org.eclipse.swt.dnd.DragSource.drag(DragSource.java:277) <BR>or=
g.eclipse.swt.dnd.DragSource.access$0(DragSource.java:267)<BR >org.eclipse=
..swt.dnd.DragSource$1.handleEvent(DragSource.java:161)<BR>org.eclipse.swt=
..widgets.EventTable.sendEvent(EventTable.java:66)<BR>org.eclipse.swt.widg=
ets.Widget.sendEvent(Widget.java:843)<BR>org.eclipse.swt.widgets.Display.=
runDeferredEvents(Display.java:3080)<BR>org.eclipse.swt.widgets.Display.r=
eadAndDispatch(Display.java:2713)<BR>org.eclipse.ui.internal.Workbench.ru=
nEventLoop(Workbench.java:1699)<BR>org.eclipse.ui.internal.Workbench.runU=
I(Workbench.java:1663)<BR>org.eclipse.ui.internal.Workbench.createAndRunW=
orkbench(Workbench.java:367)<BR>org.eclipse.ui.PlatformUI.createAndRunWor=
kbench(PlatformUI.java:143)<BR>org.eclipse.ui.internal.ide.IDEApplication=
..run(IDEApplication.java:103)<BR>org.eclipse.core.internal.runtime.Platfo=
rmActivator$1.run(PlatformActivator.java:226)<BR>org.eclipse.core.runtime=
..adaptor.EclipseStarter.run(EclipseStarter.java:376)<BR>org.eclipse.core.=
runtime.adaptor.EclipseStarter.run(EclipseStarter.java:163)<BR >sun.reflec=
t.NativeMethodAccessorImpl.invoke0(Native=20
Method)<BR>sun.reflect.NativeMethodAccessorImpl.invoke(Unknown=20
Source)<BR>sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown=20
Source)<BR>java.lang.reflect.Method.invoke(Unknown=20
Source)<BR> org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 ) <=
BR>org.eclipse.core.launcher.Main.basicRun(Main.java:278)<BR >org.eclipse.=
core.launcher.Main.run(Main.java:973)<BR>org.eclipse.core.launcher.Main.m=
ain(Main.java:948)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks</FONT></DIV></BODY></HTML>
------=_NextPart_000_0059_01C63E05.2E092E30--
Previous Topic:generate pdf document failed
Next Topic:Using rptdesign file outside a Reportproject
Current Time: Sun Nov 09 18:36:18 EST 2025
Powered by FUDForum. Page generated in 0.02978 seconds
