Re: After Installation: Plugin org.eclipse.ui is required. Must be added as a dependent plugin. [message #137959 is a reply to message #137948] |
Thu, 07 June 2007 09:25  |
That one's a toughie. Not sure. This probably means there was some
problem with the classpath and so certain required classes couldn't be
found.
See if there are any other errors like ClassDefNotFoundError in the .log.
Felix Dorner wrote:
> The error described below does not occur in a "Java Project"
> Felix Dorner escribió:
>> now I can create a Visual Class, however when the VE View says
>> "Loading" and Progress View says "Create Remote VM for Visual Editor
>> for Java" I get the following Error Message: Could not find the Main
>> Class. Program will Exit. And Later: Error trying to set new file into
>> editor.
Re: After Installation: Plugin org.eclipse.ui is required. Must be added as a dependent plugin. [message #615321 is a reply to message #137903] |
Wed, 06 June 2007 19:07  |
This says you are trying to create a RCP class or your project is a
plugin project. If your project is a plugin project, then you need to
add org.eclipse.ui as a required plugin for the plugin. That is where
you will be getting SWT from. Without this then SWT is not available so
it can't create an SWT class.
Felix Dorner wrote:
> I installed VE via the Callisto update site, when I try to create a new
> Visual Class and enter the Class Name in the form, a message pops up at
> the top of the form saying:
> I cannot continue with creating the class then. Anyone had this before?
> Felix
Re: After Installation: Plugin org.eclipse.ui is required. Must be added as a dependent plugin. [message #615328 is a reply to message #137948] |
found.
>> editor.
FUDForum. Page generated in 0.10849 seconds
