Home » Newcomers » Newcomers » Code Assist Question
Code Assist Question [message #137849] Thu, 16 February 2006 08:36 Go to next message
Originally posted by: soastuff.no-homers.org
I'm using eclipse along with PHP Eclipse plugins and I've read through the
user manuals and haven't found a solution to this yet. The only feature I
can't seem to get working that other editors like PHPEdit provide is a
more robust Code Assist. Right now if I hit CTRL+Space it will show all
current classes, variables, and built-in PHP functions. What I can't get
it to show is class properties and methods. If I have the class file open
or have typed the property/method earlier in the same file I can use ALT+/
to auto-complete the word. I've really become dependant on Code Assist
letting me choose from a list though, especially on larger projects.
Turns out I don't have every method/property memorized yet. ;) And even
if I did, I'm way too lazy to type them out every single time.
Is this feature even available? If so what do I need to do for Eclipse to
analyze my class files?
Re: Code Assist Question [message #138030 is a reply to message #137849] Fri, 17 February 2006 05:43 Go to previous message
Originally posted by: daniel.megert.eclipse.org
> the user manuals and haven't found a solution to this yet. The only
> feature I can't seem to get working that other editors like PHPEdit
> provide is a more robust Code Assist. Right now if I hit CTRL+Space
> it will show all current classes, variables, and built-in PHP
> functions. What I can't get it to show is class properties and
> methods. If I have the class file open or have typed the
> property/method earlier in the same file I can use ALT+/ to
> even if I did, I'm way too lazy to type them out every single time.
> Eclipse to analyze my class files?
You should report/ask this at the PHP Eclipse side.
Dani
Previous Topic:Quantum DB Plugin Installation
Next Topic:How to run server and client program in my PC
Current Time: Fri Nov 07 04:42:10 EST 2025
Powered by FUDForum. Page generated in 0.08758 seconds
