Re: run two test cases together [message #137738 is a reply to message #137714] |
Thu, 30 October 2008 10:56 |
Asha Messages: 28 Registered: July 2009 |
That i know..but how to run this?in quick mode or in standard mode..
Paul Slauenwhite wrote:
> Hi Ash,
> Yes. In the Behaviour tab of your test suite, add an invocation for
> each of the test cases (in the order you want) and run the test suite.
> Paul
> "Asha " <asha@readiminds.com> wrote in message
> news:b8b0e50e53fd7dc937e7282d4fc93fcb$1@www.eclipse.org...
>> Helli paul,
>> I did that whatever you suggested.let me clear my doubt. i've
>> created two test cases under same test suite.and i want one master test
>> case in which i can call two test cases which is creates before, and when
>> we run the master test case then both the test cases will run one after
>> other.
>> can we create such type of master test cases? if yes then
>> how?plz reply soon.
>>> Hi Asha,
>>> In TPTP, test suites are modeled as test cases and behaviours. Test
>>> cases are the individual test steps to exercise/evaluate the application
>>> under test. The test behaviour is which test cases (from either this
>>> test suite or other test suites) and other test suites should be executed
>>> for this test suite. You can also model behaviours are a sequential set
>>> of test invocations or create loops of test invocations or other loops.
>>> Unfortunately, two AGR test cases cannot be executed in parallel or
>>> asynchronously.
>>> Paul
>>> news:74eac83a181ce5d40fa3450c6fc7ca2b$1@www.eclipse.org...
>>>> Eugene Chan wrote:
>>>>> Hi Asha,
>>>>> You can in the test editor add the two test cases in the behavior tab
>>>>> to have them run under the same test session.
>>>>> Eugene
>>>>> news:bf747cce572f5373677d61ad69f32e83$1@www.eclipse.org...
>>>>>> can anyone tell me how to run two test cases together which is created
>>>>>> by tptp automated gui test..i m using tptp 4.4.0.2.
>>>> thanks for ur reply..can u explain it in detail..coz i didn't understand
>>>> the whole thing.i already have tried by adding test cases in behavior
>>>> tab.but while running using run dialog..it automatically closes the
>>>> eclipse..
Re: run two test cases together [message #137774 is a reply to message #137738] |
Thu, 30 October 2008 13:18 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Standard mode.
news:11373fc4497cd41d7a2a538f0655b23d$1@www.eclipse.org...
> Hi, That i know..but how to run this?in quick mode or in standard mode..
>> Hi Ash,
>> Paul
>>> Helli paul,
>>> when we run the master test case then both the test cases will run one
>>> after other.
>>> how?plz reply soon.
>>>> Hi Asha,
>>>> Test cases are the individual test steps to exercise/evaluate the
>>>> application under test. The test behaviour is which test cases (from
>>>> either this test suite or other test suites) and other test suites
>>>> should be executed for this test suite. You can also model behaviours
>>>> are a sequential set of test invocations or create loops of test
>>>> asynchronously.
>>>> Paul
>>>>> Eugene Chan wrote:
>>>>>> Hi Asha,
>>>>>> Eugene
>>>>>>> created by tptp automated gui test..i m using tptp 4.4.0.2.
>>>>> understand the whole thing.i already have tried by adding test cases
>>>>> in behavior tab.but while running using run dialog..it automatically
>>>>> closes the eclipse..
FUDForum. Page generated in 0.05672 seconds
