Re: encoding not set when creating XML file from Schema [message #137456 is a reply to message #137343] |
Thu, 08 September 2005 17:28 |
Originally posted by: amywu.us.DELETETHISPART.ibm.com
Does your schema file have an encoding? What was the encoding selected in
Preferences -> XML Files ->Creating files ->Encoding
"Iwan Birrer" <birrer@pnp-software.com> wrote in message
news:dfpfsj$2t9$1@news.eclipse.org...
> Hello,
> If I create a new XML file with "File > New > Other... > XML" and choose
> "Create XML File from an XML Schema file" I have never the change to
> set the encoding of the newly created file. By default the encoding is
> set to "null". This makes it impossible to edit this new XML file in the
> XML editor unless you change the encoding manually through the file
> properties. I am using WST 0.7.0.
> Regards,
> Iwan
FUDForum. Page generated in 0.04160 seconds
