Home » Archived » Test and Performance Tools Platform (TPTP) » BundleStatusException when running with -consoleLog argument
Re: BundleStatusException when running with -consoleLog argument [message #137238 is a reply to message #137227] |
Tue, 21 October 2008 14:53 |
Amir Yazdanshenas Messages: 8 Registered: July 2009 |
I hope you don't mind the lengthy message. The full console log is:
eclipse.buildId=I20080617-2000
java.version=1.6.0-rc
Framework arguments: -product org.eclipse.sdk.ide
Command-line arguments: -product org.eclipse.sdk.ide -data
D:\Academic\workspace/../Pasargad CRM Workspace -dev
file:D:/Academic/workspace/.metadata/.plugins/org.eclipse.pd e.core/Pasargad
CRM Workspace/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.jdt.core 4 4 2008-10-21 13:03:51.277
!MESSAGE Background Indexer Crash Recovery
!STACK 0
java.lang.OutOfMemoryError: Java heap space
at
org.eclipse.jdt.internal.compiler.util.HashtableOfObject.<init >(HashtableOfObject.java:38)
at
org.eclipse.jdt.internal.compiler.util.HashtableOfObject.reh ash(HashtableOfObject.java:139)
at
org.eclipse.jdt.internal.compiler.util.HashtableOfObject.put (HashtableOfObject.java:112)
at
org.eclipse.jdt.internal.core.index.DiskIndex.copyQueryResul ts(DiskIndex.java:349)
at
org.eclipse.jdt.internal.core.index.DiskIndex.mergeWith(Disk Index.java:522)
at org.eclipse.jdt.internal.core.index.Index.save(Index.java:18 1)
at
org.eclipse.jdt.internal.core.search.indexing.IndexManager.s aveIndex(IndexManager.java:617)
at
org.eclipse.jdt.internal.core.search.indexing.AddJarFileToIn dex.execute(AddJarFileToIndex.java:205)
at
org.eclipse.jdt.internal.core.search.processing.JobManager.r un(JobManager.java:394)
Exception in thread "Java indexing" java.lang.OutOfMemoryError: Java heap
space
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 2 0 2008-10-21 13:58:20.865
!MESSAGE While loading class
"org.eclipse.hyades.trace.ui.internal.core.TraceUIImages", thread
"Thread[main,6,main]" timed out waiting (5000ms) for thread
"Thread[Worker-9,5,main]" to finish starting bundle
" reference:file:/D:/Academic/eclipse/dropins/tptp.sdk-TPTP-4. 5.0/eclipse/plugins/org.eclipse.hyades.trace.ui_4.4.101.v200 806130100.jar
[374]". To avoid deadlock, thread "Thread[main,6,main]" is proceeding but
"org.eclipse.hyades.trace.ui.internal.core.TraceUIImages" may not be fully
initialized.
!STACK 0
org.osgi.framework.BundleException: State change in progress for bundle
" reference:file:/D:/Academic/eclipse/dropins/tptp.sdk-TPTP-4. 5.0/eclipse/plugins/org.eclipse.hyades.trace.ui_4.4.101.v200 806130100.jar "
by thread "Worker-9".
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.begi nStateChange(AbstractBundle.java:1144)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:263)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:368)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:444)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at org.eclipse.hyades.trace.ui.UIPlugin$1.run(UIPlugin.java:404 )
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Caused by:
org.eclipse.osgi.framework.internal.core.AbstractBundle$Bund leStatusException
... 39 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Yazdanshenas
Re: BundleStatusException when running with -consoleLog argument [message #137250 is a reply to message #137227] |
Tue, 21 October 2008 15:04 |
Sorry for the wrong console log. This is the correct log:
D:\Academic\workspace/../Bimeh Runtime Workspace -dev
file:D:/Academic/workspace/.metadata/.plugins/org.eclipse.pd e.core/Bimeh
Rutime Workspace/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.osgi 2 0 2008-10-21 18:32:52.608
"Thread[Worker-3,5,main]" to finish starting bundle
[840]". To avoid deadlock, thread "Thread[main,6,main]" is proceeding but
initialized.
!STACK 0
by thread "Worker-3".
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by:
... 39 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Yazdanshenas
Re: BundleStatusException when running with -consoleLog argument [message #137263 is a reply to message #137250] |
Tue, 21 October 2008 21:51 |
Eugene Chan Messages: 287 Registered: July 2009 |
Hi Amir,
It looks like there is a bug in
org.eclipse.hyades.trace.ui.UIPlugin.start(BundleContext) where the Runnable
is having some threading issue. You mentioned that you are extending TPTP,
could you try running in debug mode and investigate further? I suspect the
Display.getDefault().asyncExec(runnable); may create potential problem.
Could you please open a bug with your log and steps to reproduce the
problem?
Eugene
"Amir Yazdanshenas" <amir4042@yahoo.com> wrote in message
news:1363d5df3231b2947d1e938f0ccb7112$1@www.eclipse.org...
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> initialized.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> ... 39 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Regards
> Yazdanshenas
Re: BundleStatusException when running with -consoleLog argument [message #137275 is a reply to message #137263] |
Wed, 22 October 2008 06:45 |
Hi Eugene
I use two groups of analysis rules, one group from TPTP's owned rules, and
another group with my own analysis rules (extending from
AbstractAnalysisRule).
So I started to run each individual rule separately to find out which rule
is making the exception, and I found something strange: The rules are not
causing the problem.
The moment I click on the analysis drop-down menu in the second eclipse
workspace(the one that contains the plug-in extensions in runtime), the
console log of the first eclipse workspace (the one containing the source
code of the extensions) shows those exceptions. And again, when I close
the second workspace the console log of the first workspace shows those
exceptions.
So, it sounds like a mistake in the basic plug-in development
infrastructure, not a problem in TPTP, so I can't actually see what
happens in debug mode.
I guess you can reproduce the exception by:
1- create an plug-in development project with TPTP (I guess you already
know a lot more than I do, but I used this tutorial for that:
http://www.eclipse.org/tptp/home/documents/process/developme nt/static_analysis/TPTP_static_analysis_tutorial_part2.html)
2- Run the plug-in with the -consoleLog argument. (the second eclipse
appears on the screen)
3- Hit the analysis drop-down menu in the second eclipse workspace.
4- Check the console window in the first eclipse environment.
I just don't know what negative affects this might impose on the analysis
phase. Is it possible that some analysis errors escape?
Yazdanshenas
Re: BundleStatusException when running with -consoleLog argument [message #137283 is a reply to message #137275] |
Wed, 22 October 2008 15:49 |
Hi Amir,
According to the stack trace, it should have nothing to do with the analysis
code. It's simply the loading of some icon files of actions in toolbar, that
may be loaded when you clicked on the drop down menu. And it sounds like it
only happen when you have multiple instance of workbench running at the same
time, could you confirm that? I suspect the problem does not exist if you
run only one instance of Eclipse workbench.
I can take a further look at the problem. I will have to try reproduce the
problem first.
Eugene
news:19de558d67cc067df301016f5946d218$1@www.eclipse.org...
> Hi Eugene
> exceptions.
> Regards
> Yazdanshenas
Re: BundleStatusException when running with -consoleLog argument [message #137479 is a reply to message #137327] |
Fri, 24 October 2008 14:07 |
Hi Amir,
You are right, that is the common way to develope on Eclipse platform.
Unless the problem is blocking your development, I think you can ignore the
exception for now. It should not generate any error in the code analysis as
it is something with a TPTP image loader class only.
If you could log a bugzilla defect with your stacktrace, that would help to
trace the problem as well.
Eugene
news:3eb3c162b90567651aa6635597dbc1ad$1@www.eclipse.org...
> Hi Eugene,
> I think I didn't fully understand what you mean by having one workbench
> running. When I am developing an eclipse plug-in, I am coding it in the
> host workbench, and running/debugging it in another workbench. If I close
> the host workbench, the second workbench automatically terminates, too. So
> I have to have the two workbenches running.
> Am I wrong?
> Regards
> Yazdanshenas
Current Time: Fri Sep 20 16:06:32 GMT 2024
Powered by FUDForum. Page generated in 0.06486 seconds
