Home » Eclipse Projects » Remote Application Platform (RAP) » I18 questions
Re: I18 questions [message #137013 is a reply to message #136985] |
Thu, 18 June 2009 16:54 |
Originally posted by: benjamin.wolff.web.de
to 1.) did you take a look at RWT#setLocale() ?? that's how i do it.
to 2.) would be interesting, i couldn't figure out a way, i think this would require extensive listener usage?! in my application one can only set the language during login so i don't need on the fly language change, but it would be interesting indeed!
to 3.) sry, can't help you there, i developed with externalization, but did you check the i18n guide in the RAP developer guide?
greetings,
-ben
Aleksandar Pavlov schrieb:
> Hi there, I have a few questions about Internationalization:
> 1. Can we set the prefered language programatically. That is, to read
> the prefered language from the database and use the correct *.properties
> file.
> 2. Could the UI language be changed on the fly, without reload of the page.
> 3. What is the fastest and simplest method for externalization of
> strings in already developed application you already know, step by step.
> Thank you in advance
Re: I18 questions [message #137069 is a reply to message #137013] |
Fri, 19 June 2009 08:42 |
Aleksandar Pavlov Messages: 79 Registered: July 2009 |
Member |
Thank you for the first point, that is the thing I am looking for.
On point 3), easier development process:
yes I have read it I also figured out to alter the result from the
eclipse externalizer with two regex-es:
### reg ex
# find: Messages\.getString\("(\w+)"\)
# repl: Messages.get().$1
and then CTRL+1 on each missing field in the Message class.
Hope that is good staring point for someone new.
But for me it is kind of frustrating yet.
That's why I am asking
Thanks again
Ben W. wrote:
> greetings,
> -ben
>> *.properties file.
>> page.
Re: I18 questions [message #138175 is a reply to message #138167] |
Fri, 26 June 2009 11:34 |
hi,
i think he's refering to this post: http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg03307.html
the question remains very interesting indeed :)
greetings,
-ben
Rüdiger Herrmann schrieb:
> Aleksandar Pavlov wrote:
>> No, I haven't. It's a good start
>> Anyways, here
>> http://download.eclipse.org/technology/babel/babel_language_ packs/ganymede.php
>> I see many packages.
>> I guess only a few are responsible for RAP. Is this one correct:
>> BabelLanguagePack-eclipse-de_3.4.0.v20090524043402.zip
> If you open it, you will see. There should be fragments for the plug-ins
> that you whish to have translations for.
> E.g. org.elclipse.jface.nl_ar contains Arabic translations for plug-in
> org.eclipse.jface.
>> And another question:
>> That seems like it is eclipse specific. I guess it will work when I have
>> my RAP application started in eclipse. But is it going to work when
>> exported to WAR file.
> I am afraid, but I don't understand. *what* will work?
> Translations work from within the IDE and when deployed. Of course you
> need to include the fragments in your launch configuration.
> Please make sure you read the documentation:
> http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .rap.help/help/html/advanced/internationalization.html
>> And one last thing: the cited thread ends with the most interesting
>> qustion unanswered: "In JFace all translated texts are in a
>> message.properties file. In RAP, there exists another file
>> dialogmessages.properties which contains labels for dialog buttons. So,
>> there must be a translated version of this property file in the fragment
>> which isn't the case in the original version."
> Which "cited thread" do your refer to?
>> Thank you
>> Rüdiger Herrmann wrote:
>>> Did you read this?
>>> http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg03169.html
>>>> Hi there,
>>>> New quick question:
>>>> How can I translate the labels of the buttons in the Wizards?
>>>> They seem to be always in English.
Re: I18 questions [message #138218 is a reply to message #138175] |
Fri, 26 June 2009 12:58 |
Rüdiger Herrmann Messages: 581 Registered: July 2009 |
Ben W. wrote:
> hi,
Ah, thanks for the hint (I didn't get that).
The dialogmessages.properties is a left-over that can now probably
merged back into the original JFace messages.properties.
To make the IDialogConstants interface work for RAP we hand to
convert it into a class to be able to have multiple instances for
the multiple locales. The easies solution back then was to re-use
the RWT NLS mechanism.
Feel free to file a bugzila.
> greetings,
> -ben
>>> Anyways, here
>> plug-ins that you whish to have translations for.
>> org.eclipse.jface.
>>> Thank you
>>>> Did you read this?
>>>>> Hi there,
>>>>> New quick question:
Re: I18 questions [message #139047 is a reply to message #138218] |
Thu, 02 July 2009 16:16 |
hi,
i filed a bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=282307
greetings,
ben
> Ben W. wrote:
>> hi,
> To make the IDialogConstants interface work for RAP we hand to convert
> it into a class to be able to have multiple instances for the multiple
> locales. The easies solution back then was to re-use the RWT NLS mechanism.
>> greetings,
>> -ben
>>>> Anyways, here
>>> plug-in org.eclipse.jface.
>>>> have
>>> you need to include the fragments in your launch configuration.
>>>> fragment
>>>> Thank you
>>>>> Did you read this?
>>>>>> Hi there,
>>>>>> New quick question:
Current Time: Fri Apr 26 15:35:12 GMT 2024
Powered by FUDForum. Page generated in 0.04930 seconds
