Home » Eclipse Projects » Remote Application Platform (RAP) » I18 questions
I18 questions [message #136985] Thu, 18 June 2009 11:04 Go to next message
Hi there, I have a few questions about Internationalization:
1. Can we set the prefered language programatically. That is, to read the
prefered language from the database and use the correct *.properties file.
2. Could the UI language be changed on the fly, without reload of the page.
3. What is the fastest and simplest method for externalization of strings
in already developed application you already know, step by step.
Thank you in advance
Re: I18 questions [message #137013 is a reply to message #136985] Thu, 18 June 2009 12:54 Go to previous messageGo to next message
Originally posted by: benjamin.wolff.web.de
to 1.) did you take a look at RWT#setLocale() ?? that's how i do it.
to 2.) would be interesting, i couldn't figure out a way, i think this would require extensive listener usage?! in my application one can only set the language during login so i don't need on the fly language change, but it would be interesting indeed!
to 3.) sry, can't help you there, i developed with externalization, but did you check the i18n guide in the RAP developer guide?
greetings,
-ben
> the prefered language from the database and use the correct *.properties
> file.
> strings in already developed application you already know, step by step.
Re: I18 questions [message #137069 is a reply to message #137013] Fri, 19 June 2009 04:42 Go to previous messageGo to next message
Thank you for the first point, that is the thing I am looking for.
On point 3), easier development process:
yes I have read it I also figured out to alter the result from the
eclipse externalizer with two regex-es:
### reg ex
# find: Messages\.getString\("(\w+)"\)
# repl: Messages.get().$1
and then CTRL+1 on each missing field in the Message class.
Hope that is good staring point for someone new.
But for me it is kind of frustrating yet.
That's why I am asking
Thanks again
Ben W. wrote:
> greetings,
> -ben
>> *.properties file.
>> page.
Re: I18 questions [message #137436 is a reply to message #136985] Tue, 23 June 2009 11:41 Go to previous messageGo to next message
Hi there,
New quick question:
How can I translate the labels of the buttons in the Wizards?
They seem to be always in English.
Re: I18 questions [message #137461 is a reply to message #137436] Tue, 23 June 2009 14:14 Go to previous messageGo to next message
Did you read this?
http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg03169.html
Aleksandar Pavlov wrote:
> Hi there,
> New quick question:
Re: I18 questions [message #137496 is a reply to message #137461] Wed, 24 June 2009 03:53 Go to previous messageGo to next message
No, I haven't. It's a good start
Anyways, here
http://download.eclipse.org/technology/babel/babel_language_ packs/ganymede.php
I see many packages.
I guess only a few are responsible for RAP. Is this one correct:
BabelLanguagePack-eclipse-de_3.4.0.v20090524043402.zip
And another question:
That seems like it is eclipse specific. I guess it will work when I have
my RAP application started in eclipse. But is it going to work when
exported to WAR file.
And one last thing: the cited thread ends with the most interesting
qustion unanswered: "In JFace all translated texts are in a
message.properties file. In RAP, there exists another file
dialogmessages.properties which contains labels for dialog buttons. So,
there must be a translated version of this property file in the fragment
which isn't the case in the original version."
Thank you
Rüdiger Herrmann wrote:
> Did you read this?
>> Hi there,
>> New quick question:
Re: I18 questions [message #138167 is a reply to message #137496] Fri, 26 June 2009 07:31 Go to previous messageGo to next message
> Anyways, here
If you open it, you will see. There should be fragments for the
plug-ins that you whish to have translations for.
E.g. org.elclipse.jface.nl_ar contains Arabic translations for
plug-in org.eclipse.jface.
I am afraid, but I don't understand. *what* will work?
Translations work from within the IDE and when deployed. Of course
you need to include the fragments in your launch configuration.
Please make sure you read the documentation:
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .rap.help/help/html/advanced/internationalization.html
Which "cited thread" do your refer to?
> Thank you
>> Did you read this?
>>> Hi there,
>>> New quick question:
Re: I18 questions [message #138175 is a reply to message #138167] Fri, 26 June 2009 07:34 Go to previous messageGo to next message
hi,
i think he's refering to this post: http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg03307.html
the question remains very interesting indeed :)
greetings,
-ben
>> Anyways, here
> If you open it, you will see. There should be fragments for the plug-ins
> E.g. org.elclipse.jface.nl_ar contains Arabic translations for plug-in
> org.eclipse.jface.
> Translations work from within the IDE and when deployed. Of course you
>> Thank you
>>> Did you read this?
>>>> Hi there,
>>>> New quick question:
Re: I18 questions [message #138218 is a reply to message #138175] Fri, 26 June 2009 08:58 Go to previous messageGo to next message
Ben W. wrote:
> hi,
Ah, thanks for the hint (I didn't get that).
The dialogmessages.properties is a left-over that can now probably
merged back into the original JFace messages.properties.
To make the IDialogConstants interface work for RAP we hand to
convert it into a class to be able to have multiple instances for
the multiple locales. The easies solution back then was to re-use
the RWT NLS mechanism.
Feel free to file a bugzila.
> greetings,
> -ben
>>> Anyways, here
>> org.eclipse.jface.
>>> Thank you
>>>> Did you read this?
>>>>> Hi there,
>>>>> New quick question:
Re: I18 questions [message #139047 is a reply to message #138218] Thu, 02 July 2009 12:16 Go to previous message
hi,
i filed a bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=282307
greetings,
ben
> Ben W. wrote:
>> hi,
> To make the IDialogConstants interface work for RAP we hand to convert
> it into a class to be able to have multiple instances for the multiple
> locales. The easies solution back then was to re-use the RWT NLS mechanism.
>> greetings,
>> -ben
>>>> Anyways, here
>>>> have
>>>> fragment
>>>> Thank you
>>>>> Did you read this?
>>>>>> Hi there,
>>>>>> New quick question:
Previous Topic:verifyEvent.doit = false does not work
Next Topic:Multitab support
Current Time: Mon Nov 10 10:47:43 EST 2025
Powered by FUDForum. Page generated in 0.06599 seconds
