Re: My Perspective changes - is this normal? [message #963013 is a reply to message #962939] |
Mon, 29 October 2012 14:00 |
David Williams Messages: 722 Registered: July 2009 |
On 10/29/2012 08:53 AM, Larry Parker wrote:
> I didn't expect to see that you have never seen it happen. Every time
> I have started to use eclipse through the years, it happens all the
> time and it's frustrating. I must be doing something wrong then.
> Thank you for your reply. :p
I don't see it often, once a month or so, and its always after I've been
"flying around" clicking lots of things, hitting lots of keys, so figure
I just some how accidentally hit "cntl-something-or-other" ... but I
always just use "reset perspective" and all goes back go normal
(including what ever changes I had customized into that perspective".
So, my point is, if you open a bug, be sure to say if "reset" is not
working as you expect, or if your changes to customization are not being
saved across reset, or whatever.
Good luck,
Re: My Perspective changes - is this normal? [message #963024 is a reply to message #962939] |
Mon, 29 October 2012 14:07 |
On 10/29/2012 6:53 AM, Larry Parker wrote:
> I didn't expect to see that you have never seen it happen. Every time I
> have started to use eclipse through the years, it happens all the time
Wow, I can say that in 6-7 years of Eclipse use, I've never seen this
either. (I've always downloaded Eclipse IDE for Java EE Developers.)
Bad karma, man.
Re: My Perspective changes - is this normal? [message #963186 is a reply to message #963024] |
Mon, 29 October 2012 16:25 |
Larry Parker Messages: 8 Registered: October 2012 Location: Carson City, Nevada |
Russell Bateman wrote on Mon, 29 October 2012 07:07On 10/29/2012 6:53 AM, Larry Parker wrote:
Bad karma, man.
Funny. Yeah, I've felt jinxed alright. I also use intelliJ and I prefer that IDE, but too many books and also code on the Internet are done with eclipse.
[Updated on: Mon, 29 October 2012 16:29] Report message to a moderator
FUDForum. Page generated in 0.08979 seconds
