Home » Language IDEs » Java Development Tools (JDT) » How to get code completion in XML file
How to get code completion in XML file [message #135751] Mon, 19 January 2004 16:59 Go to next message
Some XML files like Ant build.xml have built-in code complation support.
Is it possible to have code completion for any XML file using the
corresponding DTD file ?
Is so, how ?
John Zoetebier
Web site: http://www.transparent.co.nz
Re: How to get code completion in XML file [message #135790 is a reply to message #135751] Mon, 19 January 2004 19:33 Go to previous messageGo to next message
Not that I am aware of in the Eclipse SDK.
The Ant build files used a customized Ant editor as part of the SDK Ant
plugins.
Of course you could look at the code and create your own plugin that did
what you need. Or these might already exist already...
Darins
"John Zoetebier" <john.zoetebier@transparent.co.nz> wrote in message
news:opr11l1lqxmvnwk6@news.eclipse.org...
> Is so, how ?
> John Zoetebier
Re: How to get code completion in XML file [message #135802 is a reply to message #135751] Tue, 20 January 2004 01:10 Go to previous message
Originally posted by: rsk.email.arizona.edu
Its not part of the base IDE, you need to get a plugin. XMen
(xmen.sf.net I think) is an open source plugin for XML support, its good
but buggy and progress is slow (if at all any more). XML Buddy is a good
one but commercial ($45) or you can buy an entire Web development plugin
for $30/year that has a good XML editor in it (Myeclipseide). I would
say out of all of them XMLBuddy is going to be your most featurefull
one, so it really depends on how powerful of XML editing you need. If
you just need autocomplete, I suppose XMen will do the trick for free.
> Is so, how ?
Previous Topic:Adding menu items to Java editor's context menu
Next Topic:Embedded Swing in 2.1.2?
Current Time: Sun Nov 09 12:38:04 EST 2025
Powered by FUDForum. Page generated in 0.03080 seconds
