Installed Visual editor but it doesn't show [message #135567] |
Fri, 02 February 2007 16:09 |
Originally posted by: a12684.ubi.pt
I tried to install the Visual editor for Eclipse by using the tutorial I
found on your pages (I've enabled a few repositories, then downloaded the
recommended components) but when I go to create a new project I can't see
the Visual option... What am I missing?
Bellow my install history:
13/Dez/2006 15:05:14
Date / Time Target Action Status
13/Dez/2006 15:05:55 file:/C:/Eclipse/eclipse/ site-install success
4/Jan/2007 17:47:55
4/Jan/2007 17:47:17 org.eclipse.jdt.3.2.1.patch_1.0.0 feature-install
success
4/Jan/2007 17:47:55 org.eclipse.jdt.3.2.1.patch_1.0.0 feature-enable
success
4/Jan/2007 17:47:55 org.eclipse.platform.3.2.1.patch_1.0.0 feature-install
success
4/Jan/2007 17:47:55 org.eclipse.platform.3.2.1.patch_1.0.0 feature-enable
success
4/Jan/2007 17:47:55 org.eclipse.rcp.3.2.1.patch_1.0.0 feature-install
success
4/Jan/2007 17:47:55 org.eclipse.rcp.3.2.1.patch_1.0.0 feature-enable
success
5/Jan/2007 11:20:31
5/Jan/2007 11:14:24 org.eclipse.emf.doc_2.2.1.v200609210005
feature-install success
5/Jan/2007 11:20:14 org.eclipse.emf.doc_2.2.1.v200609210005 feature-enable
success
5/Jan/2007 11:20:14 org.eclipse.emf.ecore.sdo.doc_2.2.1.v200609210005
5/Jan/2007 11:20:15 org.eclipse.emf.ecore.sdo.doc_2.2.1.v200609210005
feature-enable success
5/Jan/2007 11:20:15 org.eclipse.emf.ecore.sdo.source_2.2.0.v200609210005
5/Jan/2007 11:20:15 org.eclipse.emf.ecore.sdo_2.2.0.v200609210005
5/Jan/2007 11:20:16 org.eclipse.emf.ecore.sdo_2.2.0.v200609210005
5/Jan/2007 11:20:16 org.eclipse.emf.sdk_2.2.0.v200609210005
5/Jan/2007 11:20:22 org.eclipse.emf_2.2.1.v200609210005 feature-enable
success
5/Jan/2007 11:20:22 org.eclipse.emf.source_2.2.1.v200609210005
5/Jan/2007 11:20:22 org.eclipse.xsd_2.2.1.v200609210005 feature-enable
success
5/Jan/2007 11:20:22 org.eclipse.xsd.source_2.2.1.v200609210005
5/Jan/2007 11:20:22 org.eclipse.xsd.doc_2.2.1.v200609210005 feature-enable
success
5/Jan/2007 11:20:22 org.eclipse.emf.sdk_2.2.0.v200609210005 feature-enable
success
5/Jan/2007 11:20:22 org.eclipse.emf_2.2.1.v200609210005 feature-install
success
5/Jan/2007 11:20:22 org.eclipse.xsd_2.2.1.v200609210005 feature-install
success
5/Jan/2007 11:20:22 org.eclipse.emf.examples_2.2.0.v200609210005
5/Jan/2007 11:20:23 org.eclipse.emf.examples_2.2.0.v200609210005
5/Jan/2007 11:20:23 org.eclipse.gef.examples_3.1.1 feature-install success
5/Jan/2007 11:20:24 org.eclipse.gef.examples_3.1.1 feature-enable success
5/Jan/2007 11:20:24 org.eclipse.gef.sdk_3.1.1 feature-install success
5/Jan/2007 11:20:25 org.eclipse.gef_3.1.1 feature-enable success
5/Jan/2007 11:20:25 org.eclipse.gef.source_3.1.1 feature-enable success
5/Jan/2007 11:20:25 org.eclipse.gef.sdk_3.1.1 feature-enable success
5/Jan/2007 11:20:25 org.eclipse.gef.source_3.1.1 feature-install success
5/Jan/2007 11:20:25 org.eclipse.gef_3.1.1 feature-install success
5/Jan/2007 11:20:25 org.eclipse.ve.sdk_1.2.1.v20060825_M-u0g6D_78Wk3MLP8
5/Jan/2007 11:20:31 org.eclipse.jem_1.2.2.v20061027_M----6zXJJzM1TEVU
5/Jan/2007 11:20:31
org.eclipse.jem.source_1.2.2.v20061027_M----6zXJJzM1TEVU feature-enable
success
5/Jan/2007 11:20:31 org.eclipse.jem.sdk_1.2.2.v20061027_M-G95ETmgbY43bMdc
5/Jan/2007 11:20:31 org.eclipse.ve_1.2.1.v20060817_M-zXJUB0fxM0dxQdc
5/Jan/2007 11:20:31
org.eclipse.ve.source_1.2.1.v20060817_M-zXJUB0fxM0dxQdc feature-enable
success
5/Jan/2007 11:20:31 org.eclipse.ve.sdk_1.2.1.v20060825_M-u0g6D_78Wk3MLP8
5/Jan/2007 11:53:44
5/Jan/2007 11:53:40 org.eclipse.sdk_3.2.1.r321_v20060801-tQ1w49KnTArT0FZ
Thanks in advance
Re: Installed Visual editor but it doesn't show [message #135592 is a reply to message #135580] |
Mon, 05 February 2007 17:26 |
Thanks for the reply.
The problem is that I don't have that option... I created a new project,
and when I go to add the visual class I can't because I only have these
options:
"Right click project => New"
- Project
- Package
- Class
- Interface
- Enum
- Annotation
- Source Folder
- Folder
- File
- Untitled Text File
- JUnit Test Case
- Example
- Other
There should be an option somewhere to the Visual thing... What's
missing???
João
Re: Installed Visual editor but it doesn't show [message #135616 is a reply to message #135592] |
Tue, 06 February 2007 16:39 |
Try a clean Eclipse SDK configuration and use the Update Manager against
the Callisto update site. Pick VE, and hit the Add Required Features
button to bring in the pre-reqs.
That will make sure all of the correct stuff is installed.
Rich Kulp
Re: Installed Visual editor but it doesn't show [message #615048 is a reply to message #135580] |
options:
- Project
- Package
- Class
- Interface
- Enum
- Annotation
- Source Folder
- Folder
- File
- JUnit Test Case
- Example
- Other
missing???
João
Re: Installed Visual editor but it doesn't show [message #615050 is a reply to message #135592] |
Rich Kulp
FUDForum. Page generated in 0.04256 seconds
