Re: URL Test : How to change hostname ? [message #135458 is a reply to message #135201] |
Fri, 05 September 2008 10:50 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi Martin,
The TPTP URL Test type is used to performance test web applications,
commonly referred to as URL blasting. You can do some level of functional
testing, such as ensuring the page is available. However, the TPTP URL test
type is not intended for functional verification (e.g. page title
verification). You could manually modify the generated JUnit test code with
asserts on the various properties of the HTTP response and/or returned
resource/page.
When recording, you only need the Agent Controller or Integrated Agent
Controller on the local host (recording is only supported on the local
host). However, during playback, the test is deployed and execution on the
target host (maybe the local host), which requires the Agent Controller to
be running. The test will execute on the target host, by invoking HTTP
requests on the web application, possibly running on a different host.
Paul
"Martin Carmichael" <carmichael_martin@hotmail.com> wrote in message
news:2bbe6ea5c13197a1afe712234901c983$1@www.eclipse.org...
> Paul,
> I am not sure I understand TPTP URL tests very well.
> I need to do functional web application tests. So I Use TPTP recording
> against a web application hosted on a given machine. As far as I know,
> there is no agent controller installed on the given remote machine.
> Suppose I record web session at google. google is the remote host I test
> against and there is no agent controller there. I just want to record and
> replay back my tests cases.
FUDForum. Page generated in 0.03490 seconds
