Home » Eclipse Projects » GEF » multiple selections question
| multiple selections question [message #135110] |
Sun, 30 May 2004 21:45  |
all,
i am curious how other people are handling this situation:
i have several SelectionActions that allow for selecting more than one
object. when the user selects multiple object, the SelectionAction
iterates through the selected objects and creates commands for each
object. it then executes the commands in a compound command.
this all works well, but i fire property events for each selected object
in its model, i.e.
public void setFoo(Object foo) {
this.foo = foo;
firePropertyEvent("FOO");
this means that the diagram is going to refreshChildren() on each selected
object. this may be a lot of unnecessary overhead, versus setting all the
models, and then calling refreshChildren once.
i am wondering how others are handling this situation.
thanks,
steve
| Re: multiple selections question [message #135123 is a reply to message #135110] |
Mon, 31 May 2004 06:53   |
Originally posted by: rlemaigr.ulb.ac.be
I'm handling it just like you, because it is, the simplest way to do thi=
s =
I think, and I have the same "problem" of efficiency as you.
But this problem of efficiency is not really a big problem because:
- the users usually don't trigger operations very often, so they can be =
a =
little slow to execute, for me that's acceptable,
- the method refreshChildren is smart: it don't rebuild an EditPart for =
each model object each time the refreshChildren is called, it only build=
s =
a new EditPart only for the new objects which are in the List returned b=
y =
getModelChildren and wasn't there the last time the method =
getModelChildren was called.
And after all, when you think about it, when a user select one object an=
d =
triggers an operation that takes, let's say, 1/50 second to execute, if =
he =
selects 50 objects, he shouldn't be surprised that the operation takes n=
ow =
1 second to execute.
You could write special commands for handling a group of operations, =
writing special methods in your model for hanling such group operations =
and firing special events for signaling such group operation but that's =
not very funny :S
r=E9gis
On Mon, 31 May 2004 01:45:24 +0000 (UTC), steven melzer =
<steven.melzer@verizon.net> wrote:
> all,
> i have several SelectionActions that allow for selecting more than one=
> this all works well, but i fire property events for each selected obje=
ct
> in its model, i.e.
> this.foo =3D foo;
> this means that the diagram is going to refreshChildren() on each =
> selected
> object. this may be a lot of unnecessary overhead, versus setting all=
> the
> thanks,
> steve
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
| Re: multiple selections question [message #135183 is a reply to message #135110] |
Mon, 31 May 2004 20:37   |
> in its model, i.e.
> this.foo = foo;
Does the FOO property actually involve children? If not, you could call
only the specific refresh methods relevant to the propertychange. Secondly,
consider calling removeChild(editpart) and addChild(editpart, index) instead
of calling refreshChildren. If you can call these methods instead, then you
will see order of magnitude speed improvements.
refreshChildren() is O(n). Calling it N times means you have N^2
performance. add and removeChild are O(1).
> thanks,
> steve
| Re: multiple selections question [message #135334 is a reply to message #135183] |
Tue, 01 June 2004 08:48  |
thank you. this is very helpful. i will change my otherwise ignorant
propertyChange method in my diagram edit part to make better decisions for
refreshChildren vs. add/remove child.
steve
> > in its model, i.e.
> > this.foo = foo;
> > thanks,
> > steve
Current Time: Wed Nov 05 18:45:36 EST 2025
Powered by FUDForum. Page generated in 0.07817 seconds
