Quick and Standard mode [message #134444] |
Tue, 19 August 2008 14:25 |
Originally posted by: jakrezni.cz.ibm.com
IŽve created some Test Cases and when I simply re-play them, they work and
no error occur. But when I run them in a standard mode, it fails... before
IŽll write some more information why it fails, IŽd like to ask someone: Is
there any difference between these modes?
Thanks a lot, Jakub
Re: Quick and Standard mode [message #134507 is a reply to message #134457] |
Wed, 20 August 2008 10:09 |
thanks for your answer...I think the problem is with the items I test...
For example I right click on a XML file and "do something" with that (for
example open its properties) and when I run it in standard mode, it canŽt
select it, this is what I get, when it fails:
There was an error while running the macro associated with the test
case: XXX. org.eclipse.core.runtime.CoreException:
Error while executing a macro command: MacroCommand [item-select,
line X]
But when I simply create a Java project (File-New-Project...), it doesnŽt
fail...I suppose thereŽs something wrong when I work the created projects
and imported files. Do I have to somehow set the path to these projects?
Thanks in advance
Regards, Jakub
Re: Quick and Standard mode [message #134593 is a reply to message #134507] |
Thu, 21 August 2008 10:47 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi Jakub,
When running in Quick Mode, you are running the AGR test case in the
local workbench, as it is configured (e.g. open perspectives/views, etc.).
Using Standard Mode, it is running the test in a new workbench instance,
with the default configuration. Sometimes, your test may be expecting
certain perspectives/views to be open and there are not.
Paul
"Jakub Reznicek" <jakrezni@cz.ibm.com> wrote in message
news:7fd279b76abfc9bd91ca1bec89566df3$1@www.eclipse.org...
Re: Quick and Standard mode [message #134634 is a reply to message #134593] |
Thu, 21 August 2008 10:51 |
Hi Paul,
thanks a lot for your answer. It makes sense...so, is it possible to set
it up in TPTP configuration or do I have to do it in Eclipse itself (it
wouldnŽt be so comfortable change it all the time)?
Regards, Jakub
FUDForum. Page generated in 0.03541 seconds
