Re: a question about y-axis [message #958095 is a reply to message #955763] |
Thu, 25 October 2012 19:02 |
In your case, you could just grab the axis label and modify its value to remove the '-' or add the '-', in script. Let me know if you need an example of this.
Michael
Developer Evangelist, Silanis
Re: a question about y-axis [message #958443 is a reply to message #958391] |
Fri, 26 October 2012 01:39 |
My mistake. The easiest way I can see, to do this is to create a computed column that multiplies your axis #2 field by -1, plot this field on your second axis and then do what I said above and reverse the positive and negative values in the labels. Let me know you BIRT version if you need an example.
Michael
Re: a question about y-axis [message #958527 is a reply to message #955763] |
Fri, 26 October 2012 03:14 |
Take a look at this report. I used a scripted dataSet to recreate data similar to yours, so instead of creating a computed column in the dataSet, I made one in the chart by going to the select data tab and selecting the data bindings button and adding a binding. You can see it there. I then used this value for the second series. Finally, I reversed the values, in the second yaxis, in the chart's script. Hope this helps.
Michael
FUDForum. Page generated in 0.03584 seconds
