Re: [EMF Search] Missing sources in 0.7.0 Ganymede release (2008/06/13); Status??? [message #661534 is a reply to message #136150] |
Fri, 25 March 2011 07:36 |
Thomas Beyer Messages: 93 Registered: July 2009 |
Member |
I was wondering about the current status of the emf search (sub)project.
I have used the sdk with its wonderful and convenient generation
facility within Galileo, but can't get it working in Helios. My genmodel
throws several exceptions when trying to start the search-gen-wizard.
I understand that emf query(2) has put a lot of effort in performance on
model queries and sql-like syntax, however, I can not find a starting
point for ui integration, except starting from scratch, which is quiet
cumbersome and seems sort of awkward considering the fact, EMF search
provide(s)d high-level ui generation.
Are the development activities terminated for this feature entirely?
Are there alternatives for search ui-integration on emf-models?
I am really seeking for something to find stuff in my models.
TIA & Regards
Thomas
On 11.05.2009 10:37, Jacques LESCOT wrote:
> Hi Victor,
> due to some lack of resources and time, we won't be able to publish a
> new maintenance release. We are also planning to go through a
> Termination Review for the component since none person seems interested
> in contributing, and that we can not anymore support it.
> If suggest you to directly retrieve sources from the CVS repository.
> Regards,
> Jacques
> Víctor Roldán Betancort a écrit :
>> Hi,
>> I've come to a situation where I have to use EMF Search from the
>> Ganymede release and want to contribute new ScopeFactories. I realized
>> the corresponding extension point is only available in the integration
>> builds that start requiring Galileo components. Another problem I
>> found is that the ganymede release (the eclipse modeling bundle with
>> all incubation components) does not contain sources. Am I missing
>> something here?
>> I understand EMF Search is an incubation project and that using these
>> components (even when came out of the box with the modeling bundle) is
>> "at your own risk", so I won't complain. But... is it possible to
>> release some kind of new "maintenance" build for the ganymede release,
>> containing sources?
>> Cheers,
>> Víctor.
FUDForum. Page generated in 0.04135 seconds
