JET2 Tools broken in Juno and Keppler [message #954515] |
Tue, 23 October 2012 03:44 |
I have installed the M2T Jet2 SDK 1.1.1. from the update site at
http://download.eclipse.org/modeling/m2t/updates/releases/
into Juno and Keppler. The install passes without issue. I can validate that the features are installed in the about dialog. However,
- The New->Project->Java Emitter Project selection is unavailable
- The project properties do not show the JET properties panel
- The Run Configurations Panel does not detect jet Transformations, so they cannot be testes
This renders JET2 unusable for practical purposes.
Has anyone experienced this issue? Is there a known fix?
This is a blocker, so help is appreciated.
Re: JET2 Tools broken in Juno and Keppler [message #955063 is a reply to message #954515] |
Tue, 23 October 2012 13:28 |
Paul Elder Messages: 849 Registered: July 2009 |
Jorn:
The good news is that JET2 1.1.1 does work. I just downloaded and installed it into a new Eclipse 4.2.1, and ran it through some smoke tests.
Here is what I think is happening. The update site includes a "JET Capabilities" feature, which I suspect you installed. This feature was a requirement of one of the previous release trains, but the whole idea of releasing a capabilities feature (which restricts the visibility of features until the user requests them) was not well thought out, as it also requires the co-operation of the host product, and none of the Eclipse downloads provide that co-operation.
If you have the JET Capabilities feature installed, you can see the JET new project wizard by File > New > Project, then checking Show All Wizards. If you then select JET Transformation Project, and click Next, you will be prompted to enable the JET Development capability. Click OK. At that point, all the JET UI should be available.
Alternatively, you can uninstall the JET Capabilities:
1) Click Help > About
2) Click Installation Details
3) Find and select JET Capabilities
4) Click Uninstall, follow the wizard, and restart when prompted.
Paul
FUDForum. Page generated in 0.04352 seconds
