| Proxy Authenication details not saved [message #132653] |
Wed, 10 June 2009 05:38   |
Eclipse User  |
I have a long standing problem with saving my proxy authentication
settings on Eclipse, which I have finally decided to get to the bottom of.
I originally posted this to eclipse.platform yesterday - apologies for the
repeat post here, but hopefully this is a more suitable newsgroup.
On fresh installs of Eclipse 3.4.2 and 3.5-RC3, I have started a brand new
workspace. I did this as starting with an old workspace means that the
Preferences->General->Network Connections menu is pre-populated, and it is
here I am having problems so I wanted a brand new empty menu screen.
Then, on Eclipse 3.4.2, I select "Manual Proxy Configuration" and input my
proxy server. This is fine and if I click "Apply" then "OK" it gets saved
to the ECLIPSE/configuration/.settings/org.eclipse.core.net.prefs file.
But if I tick the "Enable Proxy Authentication" box, and enter any details
into the User Name and Password boxes, these details are never saved. This
appears to have been the case for ages with my old 3.4 installation, and
now is happening on both fresh installs on 3.4.2 and 3.5-RC3 which leads
me to conclude two things:
(a) This is quite unlikely to be a bug with eclipse, as it's a fairly
basic feature that's broken here.
(b) Whatever is causing the problem is probably specific to my
workstation. Maybe some curious security setup.
Unable to find exactly HOW the proxy authentication details are stored by
eclipse (I'm guessing not to a plain text file), I then checked my
workspace .log file, which had the following stack trace :
eclipse.buildId=M20090211-1700
java.version=1.6.0_07
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments:  -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.net 4 0 2009-06-09 16:09:13.200
!MESSAGE No password provided.
!STACK 0
org.eclipse.equinox.security.storage.StorageException: No password
provided.
 org.eclipse.equinox.internal.security.storage.SecurePreferen cesRoot.getModulePassword(SecurePreferencesRoot.java:292)
 org.eclipse.equinox.internal.security.storage.SecurePreferen cesRoot.getPassword(SecurePreferencesRoot.java:219)
 org.eclipse.equinox.internal.security.storage.SecurePreferen ces.put(SecurePreferences.java:224)
 org.eclipse.equinox.internal.security.storage.SecurePreferen cesWrapper.put(SecurePreferencesWrapper.java:110)
 org.eclipse.core.internal.net.ProxyType.saveProxyAuth(ProxyT ype.java:508)
at  org.eclipse.core.internal.net.ProxyType.setProxyData(ProxyTy pe.java:155)
 org.eclipse.core.internal.net.ProxyManager.internalSetProxyD ata(ProxyManager.java:193)
 org.eclipse.core.internal.net.ProxyManager.doSetProxyData(Pr oxyManager.java:181)
 org.eclipse.core.internal.net.ProxyManager.setProxyData(Prox yManager.java:175)
Can anyone shine any light on this stack trace ? I certainly HAVE provided
a value for "Password" on the Network connections preferences page. So I'm
guessing it's trying to use a password to store the underlying details
somewhere ? But I am stumped as to what context it's looking for a
password. This problem basically stops me from using the upgrade manager -
I used to get it working intermittently, but in recent months it just
fails without prompting me for username or password at all.
Thanks for any advice or assistance,
Ben Turner
| Re: Proxy Authenication details not saved [message #132943 is a reply to message #132917] |
Fri, 12 June 2009 09:47   |
Eclipse User  |
Thanks for the advice, Henrick.
I was able to browse my password store through the eclipse interface, and
it appeared to contain no password for the various proxy authentication
methods (HTTP, HTTPS, SOCKS).
A little more playing around and I found the <USER
HOME>/.eclipse/org.eclipse.equinox.security/secure_storage - which I
removed and then reloaded eclipse. This fixed everything; I could re-enter
all of my passwords and they were correctly saved now.
So somehow I had a problem with the old secure_storage file, related to
that stack trace, which prevented passwords being saved in any version of
eclipse on my workstation - or any other workstation I logged into, given
the <USER HOME> is a roaming directory on our network.
Problem solved - thanks.
Ben
FUDForum. Page generated in 0.05842 seconds
