Re: Configuration restore failed [message #948640 is a reply to message #948636] |
Thu, 18 October 2012 08:07 |
It sounds like you're missing a few plugins. The reason you are getting the error from PROJECT_2 and PROJECT_1 sounds like there's a plugin that is either missing or outdated.
--- Edit ---
Can you reveal more of the stack trace? You can email it to me if it's too long, or for security reasons.
* @author Steven Christou
* @dev Hudson-ci
[Updated on: Thu, 18 October 2012 08:09] Report message to a moderator
Re: Configuration restore failed [message #948674 is a reply to message #948651] |
Thu, 18 October 2012 08:54 |
The issue is your config.xml files contain elements from cascading projects (a feature that was implemented in hudson 2.2.0 and up). To fix the error upgrade to either 2.2.0 or higher.
* @dev Hudson-ci
FUDForum. Page generated in 0.02816 seconds
