Home » Newcomers » Newcomers » Quantum DB Plugin Installation
Quantum DB Plugin Installation [message #132140] Thu, 26 January 2006 09:56 Go to next message
Originally posted by: David.R.Jessop.JPMorgan.com
I have just installed Eclipse SDK 3.1.0 on a Windows XP PC, which starts
up ok.
I then downloaded Quantum db 3.0.1 and extracted into the Plugin folder.
The Eclipse Help - Software Updates - Manage Configuration lists the
com.quantum.feature 3.0.1 as Enabled.
The Window - Open Perspective does not list the Quantum 3.0.1
I have tried starting with -clean.
Please advise on how I can get Eclipse to list the Quantum db plugin.
Re: Quantum DB Plugin Installation [message #132407 is a reply to message #132140] Fri, 27 January 2006 00:31 Go to previous messageGo to next message
Originally posted by: weconsul.ptd.net
David Jessop wrote:
> up ok.
You could try reloading Eclipse with the -clear option
Ex. Eclipse -clear
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA
http://weconsultants.servebeer.com/JHackerAppManager
____________________________________________________________ ______________
'If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: Quantum DB Plugin Installation [message #132457 is a reply to message #132407] Fri, 27 January 2006 05:23 Go to previous messageGo to next message
Thanks for the -clear suggestion, however the Quantum Plugin is still not
listed.
Re: Quantum DB Plugin Installation [message #135517 is a reply to message #132457] Mon, 06 February 2006 13:43 Go to previous messageGo to next message
Originally posted by: craig.castelaz.gmail.com
The following is from $ECLIPSE_HOME/readme/readme_eclipse.html.
Manually installing features and plug-ins on a FAT file system (Windows
only)
When features and plug-ins are manually installed on top of an
Eclipse-based product install located on a FAT file system that has
already been run at least once, the product must be explicitly restarted
with the system property osgi.checkConfiguration set to true. This
property can be set in the eclipse/configuration/config.ini file, or
passed to the eclipse command line via the -vmargs option. For example,
restart with the following command: eclipse.exe -vmargs
-Dosgi.checkConfiguration=true. Then, open Help > Software Updates >
Manage Configuration dialog and toggle on the "Show disabled features"
button its toolbar. Select the newly "installed" feature and press on the
"Enable feature" action on the right pane (or select the action from the
feature's context menu). (bugs 52525, 66120, 67461)
Re: Quantum DB Plugin Installation [message #138017 is a reply to message #132140] Fri, 17 February 2006 05:30 Go to previous message
Originally posted by: ammarmar.wp.pl
If I remember correctly, the latest Quantum DB plugin requires GEF plugin
to work correctly. Make sure you have it installed.
Previous Topic:Basic plugin questions
Next Topic:Code Assist Question
Current Time: Fri Nov 07 04:42:14 EST 2025
Powered by FUDForum. Page generated in 0.11365 seconds
