fan-in/fan-out [message #132069] |
Thu, 03 July 2008 19:38 |
Originally posted by: ebraun.site.uottawa.ca
Hi all,
Using TPTP, can I get information on the number of classes a certain class
is called by (fan-in) and the number of classes it calls (fan-out)? I
would also want to know the name of the classes it calls and is called by.
Thank you very much in advance for any help you may have for me.
EB
Re: fan-in/fan-out [message #132715 is a reply to message #132583] |
Mon, 14 July 2008 19:49 |
Thanks Eugene,
Is there anyway of saving the information in a table format for all the
methods? I need this data for all my classes and I have over 100. I
need to be able to draw a diagram of who calles who in addition with some
other data.
May be I am not doing it correctly but ... I selected Execution time
Analysis and I get a list of classes in the execution summary. double
clicking on each gives me invokes and invoke by information. Do I have to
get the infomraiton class by class?
Thanks again for your help,
eb
"Eugene Chan" <ewchan@ca.ibm.com> wrote in message
news:g58077$pjj$1@build.eclipse.org...
> Hi EB,
> Yes. TPTP comes with Execution Analysis that enables you to see the
> 'invokes' and 'invoke by' information of methods that is included in the
> profile filter configuration.
> Regards.
> "eb" <ebraun@site.uottawa.ca> wrote in message
> news:g4j9sj$oth$1@build.eclipse.org...
>> Hi all,
>> class is called by (fan-in) and the number of classes it calls (fan-out)?
>> I would also want to know the name of the classes it calls and is called
>> by.
>> EB
Re: fan-in/fan-out (probekit?) [message #132764 is a reply to message #132727] |
Tue, 15 July 2008 19:05 |
Hi Eugene,
Unfortunatley I have to get the info for all of the classes and in a table
format. I just started looking at the probekit..... before I waste a lot
of time..... do you know if it is possible to get this information using the
probekit?
Do you know of any other tool (free or otherwise) that can give me the
fan-in, fan-out data? Jprofile has the data is presented on top of a class
diagram with not options to get it in a table.
Thanks for your help,
Edna
news:g5ia2q$pcn$1@build.eclipse.org...
> Hi EB,
> There Execution Detail tab provides the fan in/out information for each
> method under selection in Execution Time tab. It does not provide the
> information for all methods. However, you can try take a look at the
> Execution Flow view as well as the Trace Interactions (UML2SD) views for a
> graphical presentation of all method invocations of your profiling
> session.
> Eugene
> news:g5gal9$u3d$1@build.eclipse.org...
>> Thanks Eugene,
>> I need to be able to draw a diagram of who calles who in addition with
>> some other data.
>> to get the infomraiton class by class?
>> eb
>>> Hi EB,
>>> Regards.
>>>> Hi all,
>>>> (fan-out)? I would also want to know the name of the classes it calls
>>>> and is called by.
>>>> EB
Re: fan-in/fan-out (probekit?) [message #132823 is a reply to message #132764] |
Wed, 16 July 2008 13:09 |
Eugene Chan Messages: 287 Registered: July 2009 |
Hi Edna,
You may want to take a look at the Call Tree tab of the view that shows a
tree structure of all the execution detail.
Eugene.
news:g5isdq$i22$1@build.eclipse.org...
> Hi Eugene,
> lot of time..... do you know if it is possible to get this information
> using the probekit?
> class diagram with not options to get it in a table.
> Edna
>> Hi EB,
>> a graphical presentation of all method invocations of your profiling
>> session.
>> Eugene
>>> Thanks Eugene,
>>> some other data.
>>> have to get the infomraiton class by class?
>>> eb
>>>> Hi EB,
>>>> the profile filter configuration.
>>>> Regards.
>>>>> Hi all,
>>>>> and is called by.
>>>>> EB
Re: fan-in/fan-out (probekit?) [message #132835 is a reply to message #132823] |
Wed, 16 July 2008 13:13 |
Hi.
Not to mention that there is an Execution Flow graph that equips with a tree
table that shows all the execution detail info and breaks down the calls of
the same method by time of execution.This is closer to what you are looking
for.
Eugene
news:g5krvi$t7e$1@build.eclipse.org...
> Hi Edna,
> Eugene.
>> Hi Eugene,
>> table format. I just started looking at the probekit..... before I
>> waste a lot of time..... do you know if it is possible to get this
>> information using the probekit?
>> Edna
>>> Hi EB,
>>> session.
>>> Eugene
>>>> Thanks Eugene,
>>>> some other data.
>>>> eb
>>>>> Hi EB,
>>>>> Regards.
>>>>>> Hi all,
>>>>>> and is called by.
>>>>>> EB
FUDForum. Page generated in 0.04083 seconds
