| setTextLimit for Text Doesn't Work? [message #131929] | Thu, 07 May 2009 18:33  |  |
| Eclipse User  |  |  |  |  | I've filed a bug 275391
 ========== Pasted from the bug ===============
 Code to reproduce:
 Text text = new Text(parent, SWT.MULTI);
 text.setTextLimit(128);
 Yet I can enter as much data as I want. If I remove SWT.MULTI, then
 setTextLimit() works perfectly.
 This is a severe issue for our software due to needing to limit the amount
 of data users can enter to correspond to database limits.  It is a pain to
 hunt down all the places that this is breaking in our fairly complex
 application converted from SWT.
 If this can be fixed by M7 I would be oh so grateful.  We're just getting
 ready to ship our software the week after and I would love to update to M7
 and ship with it since it contains many bug fixes. Pleeeeeeaaaaaase~~~~ :D
 Howard
| Re: Paging  Ivan! [message #132292 is a reply to message #132279] | Tue, 12 May 2009 01:31   |  |
| Eclipse User  |  |  |  |  | Hi Howard,
 maybe you don't need to test the BackSpace character at all. In the
 verifyText if the text length is above the limit, substring it to the
 textLimit and set the event.text to the substringed value.
 Best,
 Ivan
 Howard wrote:
 > Thanks Ivan.
 > I tried to implement the verify listener, and noticed that RAP
 > VerifyEvent extends TypedEvent instead of KeyEvent like SWT. This
 > means no access to character field, so I can't test for BackSpace
 > character.  This is annoying because if I'm AT the limit, and try to
 > backspace, I'll trigger this check:
 > limit <= textField.getCharCount()
 > which means either the popping a warning, or setting e.doit=false.
 > Neither of which is pretty without the backspace check to allow
 > deletion. Any suggestions?
 > Howard
 > Ivan Furnadjiev wrote:
 >> Howard,
 >> M7 is already on the way. Patching Qooxdoo about this bug is not an
 >> easy task - this functionality is missing from the qooxdoo TextArea
 >> component (HTML textarea has no such attribute maxLength).
 >> As a workaround you can use a verify  listener to check the typed
 >> content length and not to allow the characters to exceed the max limit.
 >> Best,
 >> Ivan
 >> Howard wrote:
 >>> Thanks for the quick responses.
 >>> Is there a way for me to patch in the fix in case the Qooxdoo team
 >>> doesn't respond by Monday morning?
 >>> Also...is M7 on track to come out on Monday?  Any idea what time frame?
 >>> Howard
| Re: Still no joy...help?! [message #132426 is a reply to message #132413] | Tue, 12 May 2009 11:42   |  |
| Eclipse User  |  |  |  |  | Howard,
 get the text from the event object itself and not from the textField.
 Something like that:
 String text = event.text;
 if (limit < text.length) {
 e.text = text.substring(0, limit);
 Please note that the RAP verify event text field differ from the SWT and
 contains the complete text (not only the modified region). See this bug
 for more details:
 244008: VerifyEvent field values differ from SWT
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=244008
 Best,
 Ivan
 Howard wrote:
 > That's an interesting idea, but unless I'm doing something wrong, the
 > solution still doesn't work that well in RAP.  Works great in SWT of
 > course.
 >    if (limit < textField.getCharCount()) {
 >      e.text = textField.getText().substring(0, limit);
 > Seems like RAP doesn't get the e.start and e.end fields cleanly,
 > and/or setting e.text. I'm able to exceed the limit if I type fast.
 > And I just remembered that RAP doesn't check every character but in
 > bunches, which then makes sense that any of these solutions won't work
 > all that well.
 > I guess unless there are any more solutions, I would need to TRY to
 > help the user out by attempting to limit/warn the user, and then
 > manually truncate incoming data.
 > Howard
| Re: Still no joy...help?! [message #132467 is a reply to message #132426] | Tue, 12 May 2009 13:10  |  |
| Eclipse User  |  |  |  |  | Ah, MUCH better!  Thought I tried that too but probably didn't get it just right.  I actually was about to post that doing the check in
 ModifyListener works pretty well too since that's after the fact.
 Thanks much!
 Howard
FUDForum. Page generated in 0.10712 seconds
