Home » Archived » Test and Performance Tools Platform (TPTP) » Profiling under linux x86_64
Profiling under linux x86_64 [message #131846] |
Fri, 27 June 2008 13:47 |
Originally posted by: raphael.langella.steria.cnes.fr
I've just installed eclipse 3.4 and TPTP 4.5 and I'm trying to profile an
application with the IAC. I'm running RHEL 4u5 and JDK 1.5.0_15 (64 bits).
When I open the profiling configuration window, the monitor tab is open
and the list shows "Pending". The main window status bar says "Fetching
children of d...ollector". The terminal keeps printing :
Exception in thread
"org.eclipse.hyades.execution.core.task.ReusableThread@1da52b3b"
at
org.eclipse.hyades.execution.local.util.AgentControllerDescr iptor.versionIsAtLeast(AgentControllerDescriptor.java:67)
at
org.eclipse.hyades.execution.local.util.AgentControllerDescr iptor.isVersionAtLeast(AgentControllerDescriptor.java:194)
at
org.eclipse.hyades.execution.local.file.FileManagerFactory$3 .run(FileManagerFactory.java:413)
at
org.eclipse.hyades.execution.core.task.ReusableThread.run(Re usableThread.java:131)
at java.lang.Thread.run(Thread.java:595)
Re: Profiling under linux x86_64 [message #132431 is a reply to message #131846] |
Thu, 10 July 2008 10:04 |
Some more info :
I've started manually the ACServer, and tested the SampleClient, it works
fine.
Here is the debug log :
<CommonBaseEvent creationTime="2008-07-10T09:57:39.196365Z"
globalInstanceId="A875DD130002FEED335158C03FE9C3B5"
msg="createTransportListener (socket)" severity="5" version="1.0.1">
<sourceComponentId component="AgentController"
componentIdType="TPTPComponent" executionEnvironment="SocketListener.c,
line 915" instanceId="1000" location="linux-ci" locationType="IPV4"
processId="2020" subComponent="Socket TL" threadId="2020"
componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType
xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.196745Z"
globalInstanceId="A875DD13000300864A7D3D6F2FAA2CBE" msg="Successfully
loaded transport layer: socketTL" severity="5" version="1.0.1">
componentIdType="TPTPComponent" executionEnvironment="ConnectionManager.c,
line 184" instanceId="2" location="linux-ci" locationType="IPV4"
processId="2020" subComponent="Connection Manager" threadId="2020"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.197524Z"
globalInstanceId="A875DD13000303902A7758B330E03951" msg="Successfully
loaded command extractor: tptpCmdExtr" severity="5" version="1.0.1">
line 235" instanceId="2" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.198530Z"
globalInstanceId="A875DD130003077E461C4F2979A4A8E0"
msg="createTransportListener (named pipe)." severity="5" version="1.0.1">
componentIdType="TPTPComponent" executionEnvironment="NamedPipeListener.c,
line 946" instanceId="1001" location="linux-ci" locationType="IPV4"
processId="2020" subComponent="Named Pipe TL" threadId="2020"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.198612Z"
globalInstanceId="A875DD13000307D16A439E0065E2987B" msg="Successfully
loaded transport layer: namedPipeTL" severity="5" version="1.0.1">
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.198680Z"
globalInstanceId="A875DD1300030815018D0E9830CC9EC8" msg="Successfully
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.198777Z"
globalInstanceId="A875DD13000308751D0F59633FBAAF19"
line 946" instanceId="1002" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.198838Z"
globalInstanceId="A875DD13000308B332AB9A5E51F94122" msg="Successfully
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.198901Z"
globalInstanceId="A875DD13000308F22B1B1A3E48EBB9E3" msg="Successfully
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.199665Z"
globalInstanceId="A875DD1300030BED3B2850DF37107670"
msg="createTransportListener (shared memory)." severity="5"
version="1.0.1">
componentIdType="TPTPComponent" executionEnvironment="SharedMemListener.c,
line 112" instanceId="1003" location="linux-ci" locationType="IPV4"
processId="2020" subComponent="Shared Memory TL" threadId="2020"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.199734Z"
globalInstanceId="A875DD1300030C331FCF504231932A78" msg="Successfully
loaded transport layer: sharedMemTL" severity="5" version="1.0.1">
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.199797Z"
globalInstanceId="A875DD1300030C735CCDA3001CB4CA72" msg="Successfully
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.202847Z"
globalInstanceId="A875DD130003185A247DC5333E44D2C4" msg="Process polling
thread created, tid = 1084229984" severity="5" version="1.0.1">
componentIdType="TPTPComponent" executionEnvironment="ClientCTL.c, line
1027" instanceId="1004" location="linux-ci" locationType="IPV4"
processId="2020" subComponent="Client Compatibility TL" threadId="2020"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.202947Z"
globalInstanceId="A875DD13000318C02DACB54B0D3A92FC" msg="Successfully
loaded transport layer: tptpCCTL" severity="5" version="1.0.1">
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.203025Z"
globalInstanceId="A875DD130003190E1FCD3EB5642418CF" msg="Successfully
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.203848Z"
globalInstanceId="A875DD1300031C441AD81A6D284A8F1F" msg="ACTL process
purge thread created, tid = 1094719840" severity="5" version="1.0.1">
componentIdType="TPTPComponent" executionEnvironment="Connect2AC.c, line
1369" instanceId="1005" location="linux-ci" locationType="IPV4"
processId="2020" subComponent="Agent Compatibility TL" threadId="2020"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.203913Z"
globalInstanceId="A875DD1300031C8644FD808B2035A393" msg="Successfully
loaded transport layer: tptpACTL" severity="5" version="1.0.1">
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.203985Z"
globalInstanceId="A875DD1300031CCE0A113EFA01E45060" msg="Successfully
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.204069Z"
globalInstanceId="A875DD1300031D2140E9BB6F485D6B85" msg="Ready to start
servers" severity="5" version="1.0.1">
componentIdType="TPTPComponent" executionEnvironment="AgentController.c,
line 206" instanceId="0" location="linux-ci" locationType="IPV4"
processId="2020" subComponent="Core" threadId="2020"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.204133Z"
globalInstanceId="A875DD1300031D624B6452C34C92AB17"
msg="startTransportListener (socket)" severity="5" version="1.0.1">
line 995" instanceId="1000" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.205900Z"
globalInstanceId="A875DD1300032447002F03FA6A7943C3" msg="Socket server is
running at port number of 10006." severity="5" version="1.0.1">
line 827" instanceId="1000" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.206091Z"
globalInstanceId="A875DD130003250740438EAD4E021301" msg="Named pipe server
is running and listening at "/tmp/IBMRAC/acmasterlog" pipe."
line 920" instanceId="1001" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.206202Z"
globalInstanceId="A875DD1300032577339D647700E6D002" msg="Ready to accept
next named pipe request." severity="5" version="1.0.1">
line 1105" instanceId="1001" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.206305Z"
globalInstanceId="A875DD13000325DE57BDC276444A8697" msg="Named pipe server
is running and listening at "/tmp/IBMRAC/acmaster" pipe."
line 920" instanceId="1002" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.206408Z"
globalInstanceId="A875DD1300032645553F46AF6A96F460" msg="Ready to accept
line 1105" instanceId="1002" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.208285Z"
globalInstanceId="A875DD1300032D9A7B0A04B100598AB3" msg="ConnectionManger
- successfully added connectionID 100 for transportID 1004" severity="5"
version="1.0.1">
line 328" instanceId="2" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.209419Z"
globalInstanceId="A875DD13000332076844657D291A5ED9" msg="Client
compatibility transport layer received a command that that is recognized
(but unsupported). (iid: org.eclipse.tptp.eventProvider cmd:
listenerAccepted)" severity="5" version="1.0.1">
2279" instanceId="1004" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.209763Z"
globalInstanceId="A875DD130003335F0E14285E0934FE4C" msg="Native file
server started listening on port 10005" severity="10" version="1.0.1">
585" instanceId="1004" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.210030Z"
globalInstanceId="A875DD130003346A10F60CED440FF5D2" msg="Starting Process
Controller:/nfs/Produits/publics/x86_64.Linux.2.6.9/eclipse/ 3.4/eclipse/plugins/org.eclipse.tptp.platform.ac.linux_em64t _4.4.1.v200806171132/agent_controller/bin/tptpProcessControl ler "
componentIdType="TPTPComponent" executionEnvironment="AgentManager.c, line
3095" instanceId="1" location="linux-ci" locationType="IPV4"
processId="2020" subComponent="Agent Manager" threadId="2020"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.211293Z"
globalInstanceId="A875DD130003394564ECB2255358285D" msg="SUCCESSFULLY
started Process Controller (pid=2033)" severity="5" version="1.0.1">
3120" instanceId="1" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.211476Z"
globalInstanceId="A875DD1300033A065CF6F3103D9A5DD3" msg="Everything is
running" severity="5" version="1.0.1">
line 220" instanceId="0" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.211654Z"
globalInstanceId="A875DD1300033AC23830A72F66E081E5" msg="Shared memory
server is running and listening at "acbuffer" name."
line 326" instanceId="1003" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.212286Z"
globalInstanceId="A875DD1300033D3969AB935F2362E852" msg="Ready to accept
componentIdType="TPTPComponent" executionEnvironment="ACTLServer.c, line
449" instanceId="1005" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.242129Z"
globalInstanceId="A875DD130003B1C749292FA22DD5DE07" msg="Received(49
bytes)." severity="5" version="1.0.1">
line 854" instanceId="1002" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.242293Z"
globalInstanceId="A875DD130003B271274C96C970835DAA" msg="Validated message
of 49 bytes" severity="5" version="1.0.1">
line 770" instanceId="1002" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.242417Z"
globalInstanceId="A875DD130003B2ED2828A6B721B1B251" msg="ConnectionManger
- successfully added connectionID 101 for transportID 1002" severity="5"
version="1.0.1">
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.242487Z"
globalInstanceId="A875DD130003B3342973725C0395342B" msg="NamedPipe
getInitRequestDataBlock: returning Connection ID: 101." severity="5"
version="1.0.1">
line 163" instanceId="1002" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.242558Z"
globalInstanceId="A875DD130003B37A442A52791E836119" msg="UUID:
83d018d3-2ad8-4780-a8b3-bf45452ffc88." severity="5" version="1.0.1">
line 441" instanceId="1002" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.976049Z"
globalInstanceId="A875DD13000EE4A77A8A068C703BE64A" msg="ConnectionManger
- successfully added connectionID 102 for transportID 1004" severity="5"
version="1.0.1">
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.976857Z"
globalInstanceId="A875DD13000EE7D443939D1B36CB8803" msg="Sent 40 bytes to
client" severity="5" version="1.0.1">
componentIdType="TPTPComponent" executionEnvironment="RACClientSupport.c,
line 368" instanceId="1004" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.977563Z"
globalInstanceId="A875DD13000EEA965908A9224DE939F9" msg="ConnectionManger
- successfully added connectionID 103 for transportID 1004" severity="5"
version="1.0.1">
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:39.977777Z"
globalInstanceId="A875DD13000EEB6D4EC949F6138674A0" msg="Sent 40 bytes to
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:40.245010Z"
globalInstanceId="A875DD140003BD05487AA3C329756B12" msg="NamedPipe: Sent
16 bytes on connection ID 101" severity="5" version="1.0.1">
line 222" instanceId="1002" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:40.245296Z"
globalInstanceId="A875DD140003BE2A33B8C01F0FFE0131" msg="Ready to accept
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:40.250076Z"
globalInstanceId="A875DD140003D0D54377D11B51924AEC" msg="Received(3382
line 854" instanceId="1001" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:40.250219Z"
globalInstanceId="A875DD140003D1661D1D24A212FD3B89" msg="Validated message
of 848 bytes" severity="5" version="1.0.1">
line 770" instanceId="1001" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:40.248932Z"
globalInstanceId="A875DD140003CC3D2ED9DDD87BFCD8B3" msg="Agent's
(ProcessController) connection id is - 101" severity="5" version="1.0.1">
<sourceComponentId component="ProcessController"
componentIdType="TPTPComponent" componentType="Eclipse_TPTP"
executionEnvironment="BaseAgentImpl.cpp, line 965" instanceId="101"
location="linux-ci" locationType="IPV4" processId="2033"
subComponent="ProcessController" threadId="2033"/>
<situationType reasoningScope="INTERNAL"
reportCategory="LOG" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:type="ReportSituation"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:40.252477Z"
globalInstanceId="A875DD140003DA3837C2A2A76E3F8710" msg="Validated message
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:40.249543Z"
globalInstanceId="A875DD140003CEC11769A22D110D400B" msg="Agent(101): Bytes
in msg left to be processed: 0 bytes." severity="5" version="1.0.1">
executionEnvironment="BaseAgentImpl.cpp, line 850" instanceId="101"
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:40.253906Z"
globalInstanceId="A875DD140003DFCD5AC99E5D63045810" msg="Validated message
of 859 bytes" severity="5" version="1.0.1">
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:40.254813Z"
globalInstanceId="A875DD140003E3574D24791D1A576906" msg="Received(137
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:40.254932Z"
globalInstanceId="A875DD140003E3D03D3DBD7A374192E4" msg="Validated message
of 137 bytes" severity="5" version="1.0.1">
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:40.255895Z"
globalInstanceId="A875DD140003E78F5716D978672E8148"
msg="getApplicationAliases called" severity="5" version="1.0.1">
1831" instanceId="1" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:40.256027Z"
globalInstanceId="A875DD140003E8173BDEA08A337BC119"
msg="getApplicationAliases sending response" severity="5" version="1.0.1">
1849" instanceId="1" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:40.256152Z"
globalInstanceId="A875DD140003E8946F66A8A33A35CF58" msg="sendMessage
(named pipe) to this connection id(101)." severity="5" version="1.0.1">
line 1236" instanceId="1002" location="linux-ci" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:40.256280Z"
globalInstanceId="A875DD140003E90E29FF113B53E57421" msg="NamedPipe: Sent
496 bytes on connection ID 101" severity="5" version="1.0.1">
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-07-10T09:57:40.256464Z"
globalInstanceId="A875DD140003E9CB156737C172B618ED" msg="Ready to accept
line 110
Current Time: Tue Mar 19 09:22:26 GMT 2024
Powered by FUDForum. Page generated in 0.02271 seconds
