URL encoding not properly handled in RWT.getRequest.getParameter()? [message #131360] |
Tue, 05 May 2009 08:11 |
Originally posted by: admin.kabe-farben.ch
i think URL encoding is not properly handled in
RWT.getRequest.getParameter() / getParameterMap().
Example:
Parameter-Value: Syst%E8me%20de%20peintures%20de%20fa%E7ades (without
encoding: Système de peintures de façades)
Return-Value of RWT.getRequest.getParaemter(): Syst\ufffdme de peintures de
fa\ufffdades
Any suggetions for a workaround?
Andrej
Antw: Re: URL encoding not properly handled in RWT.getRequest.getParameter ()? [message #131594 is a reply to message #131475] |
Wed, 06 May 2009 11:21 |
Hi Rüdiger
what i'am trying to say is that special characters like é, è, à and the
like that are passed as part of a URL are all returned as Unicode \ufffd
when fetched with RWT.getRequest().getParameter(). And i do not have any
clue why.
I believe that i did encode the characters correctly in the URL (i.E. è as
%E8).
we are running tomcat 6.0.18 on a Linux box. I can hardly imagine that it
has to do with the servlet-engine (tomcat).
Maybe you have a suggestion where to start looking at.
Andrej
>>> Rüdiger Herrmann<rherrmann@eclipsesource.com> schrieb am 05.05.2009 um
19:37 in Nachricht <gtptgq$jut$1@build.eclipse.org>:
> Andrej,
> the methods you mention are defined in HttpServletRequest and thus
> are part of the servlet-engine. if you suspect the error to be there
> you would need to forward the problem report to the servlet-engine
> implementor.
> On the client-side, all request parameters that are sent by RAP
> itself are encoded using the encodeURIComponent().
> If this doesn't clarify things, please give an example and/or
> describe more exactly what you are doing.
> HTH
> Rüdiger
> Andrej Dimic wrote:
>> Hi
>> Example:
>> encoding: SystÃ̈me de peintures de façades)
> de
>> fa\ufffdades
>> Thanks
>> Andrej
Re: Antw: Re: URL encoding not properly handled in RWT.getRequest.getParameter ()? [message #131664 is a reply to message #131654] |
Thu, 07 May 2009 06:49 |
Hi Rüdiger
You can go on "www.kabe-farben.ch", then on "Baufarben / Putze".
In the left menu click on "Produkte".
Then Click on [FR] so the page changes to french.
All links are references to an RAP-Application. As you can see there are
special characters that must be encoded (the same as the text on the
web-page).
Such encoded characters will all be returned with unicode \ufffd by
RWT.getRequest().getParameter in the RAP-Application.
So we had to set placeholders like /e1, /e2 and the like so we are able to
translate back in the RAP-Application
Andrej
>>> Rüdiger Herrmann<rherrmann@eclipsesource.com> schrieb am 06.05.2009 um
22:41 in Nachricht <gtssl5$m81$1@build.eclipse.org>:
> Andrej Dimic wrote:
>> Hi Rüdiger
>> what i'am trying to say is that special characters like é, Ã̈, Ã
and
> the
>> clue why.
Ã̈
> as
>> %E8).
> I still don't understand what you are actually doing. Could you post
> some code?
> it
> Did you try a different servlet-engine or from within the IDE?
>> Thanks
>> Andrej
um
>>> Andrej,
>>> implementor.
>>> HTH
>>> Rüdiger
>>> Andrej Dimic wrote:
>>>> Hi
>>>> Example:
peintures
>>> de
>>>> fa\ufffdades
>>>> Thanks
>>>> Andrej
Re: Antw: Re: URL encoding not properly handled in RWT.getRequest.getParameter ()? [message #131683 is a reply to message #131664] |
Thu, 07 May 2009 07:52 |
Rüdiger Herrmann Messages: 581 Registered: July 2009 |
Andrej,
I still can't see any wrong encodings. All french special characters
appear as they should.
Anyway, did you make sure that encodings are handled correctly while
building? See here for example:
http://wiki.eclipse.org/RAP/FAQ#Why_are_there_encoding_issue s_after_deploying_my_RAP_application_as_a_WAR.3F
HTH
Rüdiger
Andrej Dimic wrote:
> Hi Rüdiger
> web-page).
> Thanks
> Andrej
>> Andrej Dimic wrote:
>>> Hi Rüdiger
> and
>> the
>>> clue why.
> Ã̈
>> as
>>> %E8).
>> some code?
>> it
>>> Thanks
>>> Andrej
> um
>>>> Andrej,
>>>> implementor.
>>>> HTH
>>>> Rüdiger
>>>> Andrej Dimic wrote:
>>>>> Hi
>>>>> Example:
> peintures
>>>> de
>>>>> fa\ufffdades
>>>>> Thanks
>>>>> Andrej
Re: Antw: Re: URL encoding not properly handled in RWT.getRequest.getParameter ()? [message #131736 is a reply to message #131683] |
Thu, 07 May 2009 12:41 |
Rüdiger
I try to explain otherwise:
Suppose you call an RAP Class named RapMain implementing IEntryPoint with
something like http://web-site.com?param1=<value> and <value> includes
correctly URI-encoded special characters.
In RapMain you code "String x=RWT.getRequest().getParameter(param1);".
In x, all special characters are represented by \ufffd.
That is the situation we are facing.
Andrej
>>> Rüdiger Herrmann<rherrmann@eclipsesource.com> schrieb am 07.05.2009 um
09:52 in Nachricht <gtu407$pqe$1@build.eclipse.org>:
> Andrej,
> HTH
> Rüdiger
> Andrej Dimic wrote:
>> Hi Rüdiger
>> web-page).
> to
>> Thanks
>> Andrej
um
>>> Andrej Dimic wrote:
>>>> Hi Rüdiger
Ã̈, Ã
>> and
>>> the
\ufffd
any
>>>> clue why.
>> Ã̈
>>> as
>>>> %E8).
>>> some code?
>>> it
>>>> Thanks
>>>> Andrej
05.05.2009
>> um
>>>>> Andrej,
>>>>> implementor.
>>>>> HTH
>>>>> Rüdiger
>>>>> Andrej Dimic wrote:
>>>>>> Hi
>>>>>> Example:
(without
façades)
>> peintures
>>>>> de
>>>>>> fa\ufffdades
>>>>>> Thanks
>>>>>> Andrej
Re: Antw: Re: URL encoding not properly handled in RWT.getRequest.getParameter ()? [message #132005 is a reply to message #131736] |
Fri, 08 May 2009 15:31 |
Andrej,
this took quite a while, but now I understand you. But unfortunately
I don't know much about this topic.
The HttpServletRequest is implemented by the servlet container. I
would suggest to post this question on the Tomcat or Jetty
newsgroup: Maybe there is someone that can help.
In case there is a solution to this, please share it here.
Rüdiger
Andrej Dimic wrote:
> Rüdiger
> Thanks
> Andrej
>> Andrej,
>> HTH
>> Rüdiger
>> Andrej Dimic wrote:
>>> Hi Rüdiger
>>> web-page).
>> to
>>> Thanks
>>> Andrej
> um
>>>> Andrej Dimic wrote:
>>>>> Hi Rüdiger
> Ã̈, Ã
>>> and
>>>> the
> \ufffd
> any
>>>>> clue why.
>>> Ã̈
>>>> as
>>>>> %E8).
>>>> some code?
>>>> it
>>>>> Thanks
>>>>> Andrej
> 05.05.2009
>>> um
>>>>>> Andrej,
>>>>>> implementor.
>>>>>> HTH
>>>>>> Rüdiger
>>>>>> Andrej Dimic wrote:
>>>>>>> Hi
>>>>>>> Example:
> (without
> façades)
>>> peintures
>>>>>> de
>>>>>>> fa\ufffdades
>>>>>>> Thanks
>>>>>>> Andrej
FUDForum. Page generated in 0.04336 seconds
