| Singlesourcing Branding (Splashscreen) [message #131062] | Mon, 04 May 2009 09:33  |  |
| Eclipse User  |  |  |  |  | Originally posted by: bjoern.bjoernfischer.de
 Hello everybody,
 in our RAP application we use a branding (extension point
 org.eclipse.rap.ui.branding) that includes a cusotom favicon, title and
 body (which contains html showing a splash image and a feedback gif).
 Since we are single sourcing, we put the rap-branding-specific files in
 a folder named "html" in the rap fragment. This configuration shows the
 branding when starting my app from the IDE.
 But when deploying the app on a web container we gained a
 NullPointerException concerning the branding. After some time of
 investigation I found out that putting the branding files into the
 host-bunle (my.application) does the trick. Now I see the branding when
 invoking the app on the web container.
 Unfortionately this is not a very elegant solution concerning single
 sourcing, since the host bundle should not contain any rap specific
 artefacts (like the html and pictures for the rap branding). Does anyone
 know how to leave the files in the rap fragment and make them known to
 rap at runtime?
 Thanks in advance!
 Björn
| Re: Singlesourcing Branding (Splashscreen) [message #135041 is a reply to message #131074] | Fri, 05 June 2009 06:37  |  |
 Hi Benny,
 I thouht that I checked the build.properties before posting. But
 recently I tried to remove the branding stuff from the host bundle, and
 it still works. So probably that was the issue. Anyway thanks for your
 explanation.
 Björn
 Benjamin Muskalla schrieb:
 > Hi Björn,
 > the first thing you should check is that all the files are included in
 > your build.properties file. Otherwise they are not exported by PDE and
 > cannot be found after deploying the application.
 > Cheers
 >   Benny
FUDForum. Page generated in 0.04113 seconds
