JVMTI agen not available [message #130236] |
Sun, 18 May 2008 15:22 |
Originally posted by: roland.depratti.cox.net
I am running TPTP 4.3.1 under Eclipse 3.2.2 in WinXP/SP2.
I can run profiling under the non-agent method successfully, but when I
try to use the Agent controller I receive errors:
The agent controller is started as a windows service
- When hitting Test Availing in the profile configuration, I get:
The JVMTI agent org.eclipse.tptp. jvtmi is not available. I was an
earlier post from Asaf concerning checking that the profiler plugin is
installed in the AC Server plugin directory and it is. I also turned
on
the Martini log and have attached that file.
- When I try to run a profile I get the following message:
org.eclipse.core.runtime.CoreException
Agent Controller is unavailable under port -1. Make sure that the
service is started and the port number is correct under preferences.
org.eclipse.tptp.platform.execution.exceptions.AgentControll erUnavailableExcept
ion: Error: Unable to connect to the Agent Controller.port out of
range: -1
at
org.eclipse.tptp.platform.execution.client.core.internal.Nod eImpl.connect
(Unknown Source) at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.uti l.AgentControllerDelegate$1$EstablishConnection.run(Unknown
Source)
My basic purpose is to do profiling and track elapsed time at the line
level. The eclipse profiling from the earlier method gives me method level
stats, but because I am using jdbc in this application, I am having hard
time determining which of my code calls to a jdbc method is responsible.
- rd
Re: JVMTI agen not available (forgot Martini log) [message #130250 is a reply to message #130236] |
Sun, 18 May 2008 15:25 |
Sorry,
Here is the output form the Martini log:
Process ID: 2920
Process command line: "c:\Program Files\Java\jre1.5.0_13\bin\java.exe"
-agentlib:JPIBootLoader=JPIAgent:server=controlled;CGProf
org.eclipse.tptp.martini.HeapProxy
Machine name: DELLE520
Type Date Time TID Level Client Message
Informative 05/18/08 14:58:25 2208 0 CJVMTIInterface Using JVMTI
FUDForum. Page generated in 0.03452 seconds
