Home » Eclipse Projects » Plugin Development Environment (PDE) » TerminatingClassNotFoundException when loading org.eclipse.core.runtime.Platform
icon8.gif  TerminatingClassNotFoundException when loading org.eclipse.core.runtime.Platform [message #941023] Fri, 12 October 2012 02:43
UPDATE2:
Update 1 was incorrect so deleted it...
The real problem was, that the .fileTable.xx file under configuration\org.eclipse.core.runtime\.manager\ was corrupted in a manner that it missed a lot of entries, so the StorageManager couldn't find the files and threw an NPE. (The checksum was the same though if I remember correctly.)
I must believe that the user have terminated the framework from the task manager but I wasn't able to reproduce it.
Hello
I have a very strange problem.
Osgi 3.5.1 runs on a win 7 machine.
I'm trying to start the osgi framework and at the point of loading org.eclipse.core.runtime.Platform it fails with the exception in the title. Sometimes I manage to reach InternalPlatform.getRegistry (when Platform.getExtensionRegistry succeeds) but then a classnotfoundexception happens there.
None of us experienced this before but now we gave the program away to someone else. For a few times initially everything works fine for her but after that the framework finally gets into this state and the only solution we found so far was to reinstall the whole app.
I've already read around and found that this has something with insufficient privileges, but can't fix it for myself.
If you need more details to help, tell.
thanks
David
Stack below:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNot
FoundException: An error occurred while automatically activating bundle org.ecli
pse.equinox.registry (83).
        at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFind
LocalClass(EclipseLazyStarter.java:125)
        at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(C
lasspathManager.java:449)
        at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalCla
ss(DefaultClassLoader.java:211)
        at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLo
ader.java:381)
        at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(Single
SourcePackage.java:33)
        at org.eclipse.osgi.internal.loader.MultiSourcePackage.loadClass(MultiSo
urcePackage.java:31)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(Bundl
eLoader.java:454)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.
java:410)
java:398)
        at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(De
faultClassLoader.java:105)
        at java.lang.Class.forName0(Native Method)
        at java.lang.Class.forName(Unknown Source)
        at org.eclipse.equinox.internal.app.Activator.start(Activator.java:55)
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(Bund
leContextImpl.java:783)
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActiv
ator(BundleContextImpl.java:774)
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(Bund
leContextImpl.java:755)
        at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(Bundl
eHost.java:352)
        at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(Abstrac
tBundle.java:280)
        at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:
408)
LocalClass(EclipseLazyStarter.java:111)
ader.java:381)
eLoader.java:454)
java:410)
java:398)
        at org.eclipse.core.internal.runtime.PlatformActivator.startAppContainer
(PlatformActivator.java:47)
        at org.eclipse.core.internal.runtime.PlatformActivator.start(PlatformAct
ivator.java:32)
eHost.java:352)
        at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(Abstra
ctBundle.java:370)
        at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Frame
work.java:1068)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBund
les(StartLevelManager.java:557)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(St
artLevelManager.java:464)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStart
Level(StartLevelManager.java:248)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEv
ent(StartLevelManager.java:445)
        at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventM
anager.java:227)
        at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(Even
tManager.java:337)
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.int
ernal.registry.osgi.Activator.start() of bundle org.eclipse.equinox.registry.
ator(BundleContextImpl.java:806)
eHost.java:352)
tBundle.java:280)
408)
        ... 45 more
Caused by: java.lang.NullPointerException
        at org.eclipse.core.internal.registry.BufferedRandomInputStream.<init>(B
ufferedRandomInputStream.java:41)
ufferedRandomInputStream.java:37)
        at org.eclipse.core.internal.registry.TableReader.setExtraDataFile(Table
Reader.java:76)
        at org.eclipse.core.internal.registry.ExtensionRegistry.<init>(Extension
Registry.java:657)
        at org.eclipse.core.runtime.RegistryFactory.createRegistry(RegistryFacto
ry.java:59)
        at org.eclipse.core.internal.registry.osgi.Activator.startRegistry(Activ
ator.java:135)
        at org.eclipse.core.internal.registry.osgi.Activator.start(Activator.jav
a:56)
        ... 50 more
java.lang.NoClassDefFoundError: org/eclipse/core/runtime/RegistryFactory
        at org.eclipse.core.internal.runtime.InternalPlatform.getRegistry(Intern
alPlatform.java:548)
        at org.eclipse.core.runtime.Platform.getExtensionRegistry(Platform.java:
910)
        at com.ge.med.solo.workflow.WorkflowUtil.init(WorkflowUtil.java:23)
        at com.ge.med.solo.workflow.WorkflowUtil.getElement(WorkflowUtil.java:41
        at com.ge.med.solo.solomini.SoloMini.start(SoloMini.java:84)
        at com.ge.med.solo.solomini.SoloMini.activate(SoloMini.java:56)
        at org.eclipse.equinox.internal.ds.model.ServiceComponent.activate(Servi
ceComponent.java:206)
        at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.activate(S
erviceComponentProp.java:140)
        at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(Serv
iceComponentProp.java:330)
        at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(Instan
ceProcess.java:560)
        at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(Insta
nceProcess.java:182)
        at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver
.java:393)
        at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.ja
va:176)
        at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.jav
a:791)
        at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRMana
ger.java:758)
        at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:90)
        at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Ex
ecutor.java:70)
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$Terminat
ingClassNotFoundException: An error occurred while automatically activating bund
le org.eclipse.equinox.registry (83).
ader.java:381)
eLoader.java:454)
java:410)
java:398)
eHost.java:352)
tBundle.java:280)
408)
ader.java:381)
eLoader.java:454)
java:410)
java:398)
ivator.java:32)
eHost.java:352)
ctBundle.java:370)
work.java:1068)
anager.java:227)
tManager.java:337)
eHost.java:352)
tBundle.java:280)
408)
        ... 45 more
Reader.java:76)
Registry.java:657)
ry.java:59)
ator.java:135)
a:56)
        ... 50 more
[Updated on: Fri, 12 October 2012 10:52] by Moderator
Previous Topic:Check for PlugIn-Update automatically
Next Topic:how can I expand the editor in eclipse?
Current Time: Sun Nov 09 18:36:08 EST 2025
Powered by FUDForum. Page generated in 0.03463 seconds
