Home » Archived » Test and Performance Tools Platform (TPTP) » Agent Controller fails to start on linux
Agent Controller fails to start on linux [message #129848] |
Wed, 07 May 2008 16:01 |
Originally posted by: cvkmurthy.hotmail.com
Experts,
I am getting following error when I start Agent Controller on linux.
Configuration of the machine is as follows. Agent Controller version is
4.2.0.2. Please advice.
$ uname -a
Linux pnli6005 2.6.5-7.191-smp #1 SMP Tue Jun 28 14:58:56 UTC 2005 86_64
x86_64 x86_64 GNU/Linux
$ ./RAStart.sh
Starting Agent Controller
../RAStart.sh: line 44: ../bin/RAServer: cannot execute binary file
RAServer failed to start
Krishna
Re: Agent Controller fails to start on linux [message #129911 is a reply to message #129848] |
Thu, 08 May 2008 16:48 |
Originally posted by: dmohr.cs.unm.edu
Krishna wrote:
> Experts,
> $ uname -a
> $ ./RAStart.sh
> Regards,
> Krishna
Looks to me like you probably have a 32bit binary, which doesn't want to
run on your 64bit system.
~David
Re: Agent Controller fails to start on linux [message #129922 is a reply to message #129911] |
Fri, 09 May 2008 05:26 |
David Mohr wrote:
> Krishna wrote:
>> Experts,
>> is 4.2.0.2. Please advice.
>> $ uname -a
>> 86_64 x86_64 x86_64 GNU/Linux
>> $ ./RAStart.sh
>> Regards,
>> Krishna
> ~David
As you can see below I am running 64 bit binary. Did any body get this
working on linux? If yes, can you please pass on the configurations of
the machine and version of Agent Controller?
$ file RAServer
RAServer: ELF 64-bit MSB executable, cisco 7500, version 1 (SYSV), for
GNU/Linux
2.4.19, dynamically linked (uses shared libs), not stripped
I have execute permissions for RAServer
$ ls -lrt
total 148
-rwxr-xr-x 1 chakrava iman 128 2006-06-19 05:07 SetConfig.sh*
-rwxr-xr-x 1 chakrava iman 133977 2006-06-19 05:24 RAServer*
-rwxr-xr-x 1 chakrava iman 685 2006-06-19 05:24 RAStop.sh*
-rwxr-xr-x 1 chakrava iman 1538 2006-06-19 05:24 RAStart.sh*
Krishna
Re: Agent Controller fails to start on linux [message #129934 is a reply to message #129922] |
Fri, 09 May 2008 16:19 |
Krishna wrote:
> David Mohr wrote:
>> Krishna wrote:
>>> Experts,
>>> linux. Configuration of the machine is as follows. Agent Controller
>>> version is 4.2.0.2. Please advice.
>>> $ uname -a
>>> $ ./RAStart.sh
>>> Regards,
>>> Krishna
>> to run on your 64bit system.
>> ~David
> $ file RAServer
> GNU/Linux
You are not misinterpreting the output of file. Yes, it's 64bit, but
it's not x86 :-). Look at the cisco 7500, in place o that you should
have x86_64. So the correct output would be:
bin/RAServer: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), for
GNU/Linux 2.4.0, dynamically linked (uses shared libs), not stripped
> $ ls -lrt
> total 148
> Regards,
> Krishna
~David
Re: Agent Controller fails to start on linux [message #130032 is a reply to message #129934] |
Wed, 14 May 2008 04:47 |
David Mohr wrote:
> Krishna wrote:
>> David Mohr wrote:
>>> Krishna wrote:
>>>> Experts,
>>>> $ uname -a
>>>> $ ./RAStart.sh
>>>> Regards,
>>>> Krishna
>>> ~David
>> $ file RAServer
>> GNU/Linux
>> $ ls -lrt
>> total 148
>> Regards,
>> Krishna
> ~David
Does it means that I cannot run Agent Controller on my linux machine? Or
is there a different Agent Controller download available at TPTP site
for my machine configuration.
Krishna
Current Time: Sat Apr 27 00:17:45 GMT 2024
Powered by FUDForum. Page generated in 0.03446 seconds
