Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Transaction.OPTION_NO_UNDO
Transaction.OPTION_NO_UNDO [message #129719] |
Wed, 17 September 2008 05:26  |
Originally posted by: andreas-scharf.gmx.de
I wrote an action whic the user can call within a view (not an editor).
The action modifies some resources (i.e. it deletes objects) and then
I've to save the resources that were affected automatically. I don't
want the user to undo these changes in any opened editor, so I did this:
editingDomain.getCommandStack().execute(
DeleteCommand.create(editingDomain, preparedSelection),
Collections.singletonMap(Transaction.OPTION_NO_UNDO, Boolean.TRUE));
The problem is, that my editor still get's dirty and enables the undo
action. That's fatal because the user then presses undo, the editor
isn't dirty anymore but the resource doesn't get saved (since save was
not included in the deleteCommand of course).
Do I have to manually react in my editor on this transaction flag which
I've set above and don't let the editor get dirty? I thought that would
automatically handled by not notifiying any IOperationHistoryListeners.
I should mention that I'm using the WorkspaceCommandStack.
Andreas
Re: Transaction.OPTION_NO_UNDO [message #129733 is a reply to message #129719] |
Wed, 17 September 2008 08:46   |
Originally posted by: cdamus.zeligsoft.com
Hi, Andreas,
This option simply instructs the transaction not to record undo
information, and should generally be used only when there is no need to
record it because you already have the undo information in hand. This
is the case, for example, in the transactions that are used for undoing
and redoing Commands (including RecordingCommands) on a CommandStack or
IUndoableOperations (including AbstractEMFOperations) on the
IOperationHistory.
Perhaps it makes sense that the operation created by the
WorkspaceCommandStack to wrap the command should not be undoable() if
this option was supplied. I am only concerned that it is a change in
the semantics (from "just don't record undo information" to "these
changes are not undoable). Perhaps you can raise an enhancement
request, for addition of a new option? It may be called EXECUTE_ONLY or
NOT_UNDOABLE. Suggestions for an option name are welcome.
Christian
Andreas Scharf wrote:
> Andreas
Re: Transaction.OPTION_NO_UNDO [message #129745 is a reply to message #129733] |
Thu, 18 September 2008 09:19  |
Christian,
that would be very great ;). I solved it by creating a command which is
undoable which is of course the same as an operation which is undoable.
However such an option would be very helpful and NOT_UNDOABLE sounds good.
Andreas
Christian W. Damus schrieb:
> Hi, Andreas,
> IOperationHistory.
> Cheers,
> Christian
>> editor). The action modifies some resources (i.e. it deletes objects)
>> and then I've to save the resources that were affected automatically.
>> I don't
>> which I've set above and don't let the editor get dirty? I thought
>> that would automatically handled by not notifiying any
>> Regards,
>> Andreas
Re: Transaction.OPTION_NO_UNDO [message #620313 is a reply to message #129719] |
Hi, Andreas,
IOperationHistory.
Christian
> Andreas
Re: Transaction.OPTION_NO_UNDO [message #620314 is a reply to message #129733] |
Christian,
Andreas
> Hi, Andreas,
> IOperationHistory.
> Cheers,
> Christian
>> I don't
>> Regards,
>> Andreas
Current Time: Wed Jul 02 06:18:48 EDT 2025
Powered by FUDForum. Page generated in 0.03114 seconds
