Re: compare XML files not having same MetaModel ? [message #957540 is a reply to message #938953] |
Thu, 25 October 2012 09:47 |
Philippe,
EMF Compare works on EMF models : if you implement your transformation before calling EMF Compare with them, you won't have integration problems. Note that you do not have to save the models before feeding them to compare if you're using it programmatically.
Your issue, then, is how to transform the models beforehand. For that you'll have to determine exactly what you wish to do, and with what tool : Java, ATL, ... look at the model-to-model tools on Eclipse.
Laurent Goubet
Obeo
Re: compare XML files not having same MetaModel ? [message #962700 is a reply to message #958898] |
Mon, 29 October 2012 09:01 |
Philippe,
I'd say that your best bet would be to define a metamodel that can properly describe the data you have in both models instead of trying to strip irrelevant data. Or to convert one of the two to the metamodel of the other and compare these two files.
Whatever the case, you might want to ask on the EMF newsgroup whether someone already had such a need.
Laurent Goubet
Obeo
FUDForum. Page generated in 0.03534 seconds
