Home » Modeling » EMF » [Teneo] Adding EPackages Dynamically to DataStore
[Teneo] Adding EPackages Dynamically to DataStore [message #938743] Wed, 10 October 2012 01:39 Go to next message
Hi Everyone,
Is there anyway I can dynamically include EPackages in to datastore during runtime ?
My Code:
//Initializing with a simple EPackage
EPackage[] epacks = new EPackage[]{EcoreFactory.eINSTANCE.createEPackage()};
hbds.setEPackages(epacks);
hbds.initialize();
Later updating Registry with actual EPackages.
 EPackage.Registry.INSTANCE.put( epack.getNsURI(), epack );
Will Teneo automatically pick from global EPackage.Registry the packages at runtime?
Teneo gives me below error:
java.lang.IllegalArgumentException: No annotated model element present for: type EClass has its epackage been registered with Teneo?
Thanks and Regards,
Appasamy
Re: [Teneo] Adding EPackages Dynamically to DataStore [message #938802 is a reply to message #938743] Wed, 10 October 2012 02:59 Go to previous messageGo to next message
Hi Appasamy,
I am afraid that this won't work like this. The datastore should be initialized with the actual epackage instance. So if
you have new epackages then you need to initialize the datastore again with those.
gr. Martin
On 10/10/2012 07:39 AM, Appasamy Thirugnana wrote:
> Hi Everyone,
> My Code:
> hbds.initialize();
> with Teneo?
> Thanks and Regards,
> Appasamy
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] Adding EPackages Dynamically to DataStore [message #938818 is a reply to message #938802] Wed, 10 October 2012 03:21 Go to previous messageGo to next message
Hi Martin,
Thanks for the input.
Ok I understood that I have to reinitialize the data store and I am following
http://wiki.eclipse.org/Teneo/Hibernate/Dynamic_EMF_Tutorial#Create_and_persist_Dynamic_EObject
Here will there be a problem if 5 concurrent users trying to persist instances using the datastore and one of the user triggers for reinitialization of datastore.
Will teneo manage to hold the reinitialization till all the transactions get complete and execute re-initialization later.
We have a spring web application with Sessionfactory implemented as per below configuration.
sebthom.de/152-configuring-emf-teneo-hibernate-dbcp-spring-transactions-opensessioninviewfilter/
Thanks ,
Appasamy
Re: [Teneo] Adding EPackages Dynamically to DataStore [message #938823 is a reply to message #938802] Wed, 10 October 2012 03:27 Go to previous messageGo to next message
Hi Martin,
Thanks ,
Appasamy
Re: [Teneo] Adding EPackages Dynamically to DataStore [message #938859 is a reply to message #938823] Wed, 10 October 2012 04:10 Go to previous messageGo to next message
Hi Appasamy,
Re-initializing the datastore is the same as re-initializing the sessionfactory. In most application the
sessionfactory/datastore is setup/initialized when the application starts not during normal operation.
If you have a dynamic model, then the best way is to create a new datastore with the new epackages and then after
initializing the new datastore switch the old and new one in a thread-safe way. This is quite doable.
gr. Martin
On 10/10/2012 09:27 AM, Appasamy Thirugnana wrote:
> Hi Martin,
> Thanks ,
> Appasamy
The Netherlands
Re: [Teneo] Adding EPackages Dynamically to DataStore [message #938865 is a reply to message #938859] Wed, 10 October 2012 04:19 Go to previous message
Hi Martin,
Thanks for the information. I understood now. Thanks for the support provided.
Appasamy
Previous Topic:BinaryResource lost unsettable empty values
Next Topic:Why to use a Map when EKeys are possible?
Current Time: Mon Oct 27 14:05:55 EDT 2025
Powered by FUDForum. Page generated in 0.26554 seconds
