Home » Eclipse Projects » Remote Application Platform (RAP) » Deploy NLS Problem
Deploy NLS Problem [message #129022] Tue, 21 April 2009 07:34 Go to next message
May is currently offline MayFriend
I've got a problem with the deployment of my rap-app on Tomcat. When I
start my app (a contact management application) on the integrated
jetty-server it works fine. The German and English languages are chosen
correctly. I also checked my manifest-configuration for building, export
and dependencies
When I deploy the app on tomcat as war-file it doesn't show up.
The OSGi consoloutput is as follows:
java.util.MissingResourceException: Can't find bundle for base name
de.mycompany.rap.messages, locale de_DE
at java.util.ResourceBundle.throwMissingResourceException(Unkno wn
Source)
at java.util.ResourceBundle.getBundleImpl(Unknown Source)
at java.util.ResourceBundle.getBundle(Unknown Source)
at org.eclipse.rwt.RWT$NLS.getISO8859_1Encoded(RWT.java:98)
at de.ipsways.rap.helper.Messages.get(Messages.java:63)
at
de.ipsways.rap.activator.ApplicationActionBarAdvisor.makeAct ions(Appl
icationActionBarAdvisor.java:65)
The "OSGi-ss-command" shows no unresolved constrains.
(When I replace the Message strings with hardcoded string it works fine at
tomcat as well)
I currently write my degree thesis (Dipomarbeit) about RAP and I would
really appreciate your help,
Konstantin May
Re: Deploy NLS Problem [message #129037 is a reply to message #129022] Tue, 21 April 2009 08:25 Go to previous messageGo to next message
Stefan   is currently offline Stefan Friend
two ideas what might be wrong:
1. Do you use fragments to provide the missing language? If so, you
could check if this fragment is used during build time (feature.xml) and
is running (OSGi console).
2. Make sure that the property file is referenced in your
build.properties (bin.includes). You can also unpack the jar of your
deployed app and check if the resource file is there.
Stefan.
May schrieb:
> and dependencies
> Source)
> at
> at tomcat as well)
> Konstantin May
Re: Deploy NLS Problem [message #129050 is a reply to message #129022] Tue, 21 April 2009 09:18 Go to previous messageGo to next message
Sergey N. Yashin is currently offline Sergey N. YashinFriend
Member
Hi!
You need to put your bunle "de.mycompany.rap.messages_XX" in the
config.ini to the list of the osgi bunles, just put in the list like ",
de.mycompany.rap.messages_XX" and do not add "@start" postfix to the this
fragment.
Re: Deploy NLS Problem [message #129361 is a reply to message #129037] Wed, 22 April 2009 08:36 Go to previous message
Thanks for your help,
I finally found out that I have used "de.mycompany.rap.messages.Messages"
instead of "de.mycompany.rap.messages.messages" in the Message class.
On Jetty this doesen't matter, but on tomcat...
Changing to lower case does the trick ;-)
Previous Topic:TableTree support?
Next Topic:Suuport for tabbed properties view?
Current Time: Tue Mar 28 15:12:30 GMT 2023
Powered by FUDForum. Page generated in 0.01601 seconds
