jsp taglib [message #128884] |
Tue, 02 August 2005 13:55 |
Originally posted by: aurphir.aurphir.com
Hi all
Eclipse webtools support jsp taglib or not? because whle editing it says
unknown tag
Re: jsp taglib [message #128923 is a reply to message #128884] |
Tue, 02 August 2005 14:26 |
Originally posted by: pavery.us.ibm.com
Vishal Rana wrote:
> Hi all
> unknown tag
> Thanks
There is support for JSP taglib.
If you're seeing "unknown tag" errors, there might be a couple of reasons...
What type of project are you in? Are you in a web project?
How are you referencing your taglibs in your JSPs?
some examples:
<%// specified in web.xml file%>
<%@ taglib uri="/tags/struts-bean" prefix="bean" %>
<%// relative to WebContent folder %>
<%@ taglib uri="/WEB-INF/struts-bean.tld" prefix="bean" %>
<%// relative to your JSP file %>
<%@ taglib uri="./struts-bean.tld" prefix="bean" %>
-phil
Re: jsp taglib [message #128936 is a reply to message #128923] |
Tue, 02 August 2005 14:40 |
Well I am simply putting a test.tld in WEB-INF folder
and calling it in test.jsp like <%@ taglib prefix="test"
uri="WEB-INF/test.tld" %>
but I don't know what to write in web.xml
"phil avery" <pavery@us.ibm.com> wrote in message
news:dcnvqe$pse$1@news.eclipse.org...
> Vishal Rana wrote:
> > Hi all
> > unknown tag
> > Thanks
reasons...
> some examples:
> -phil
Re: jsp taglib [message #129015 is a reply to message #128936] |
Tue, 02 August 2005 16:33 |
Actually, you don't "have" to change the web.xml file.
<%@ taglib prefix="test" uri="/WEB-INF/test.tld" %>
should work in your case (assuming you're in a web project)
note the leading "/" in the uri, this "should" resolve to the WebContent
folder.
Hopefully this solves your problem.
>>Vishal Rana wrote:
>>>Hi all
>>>unknown tag
>>>Thanks
> reasons...
>>some examples:
>>-phil
Re: jsp taglib [message #129169 is a reply to message #128936] |
Tue, 02 August 2005 20:21 |
Ignoring the web.xml for now, where is the test.jsp file located?
If it's not in the parent folder of WEB-INF, the uri value as-is
probably won't work.
- Nitin
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: jsp taglib [message #129181 is a reply to message #129117] |
Tue, 02 August 2005 20:27 |
David Goodenough wrote:
> Well that is interesting, as I am having a real problem with WTP and JSP
> taglibs. I have my taglib tags in an included JSP file, and while WTP
> does things like content assist in the file that is included (the one with
> the taglibs) it does not work and I get lots of yellow underlines about the
> <c: tags in the including file. The one difference with what you have
> written above is that I use TLDs included in the JAR files from the
> WEB-INF/lib directory. So my taglib tag looks like:-
> <%@ taglib uri="http://java.sun.com/jsp/jstl/core" prefix="c" %>
> This works quite happily under Tomcat 5.5 (which is the server for this
> project) and used to work with Lomboz under Eclipse 3.0 but does not work
> with WTP 0.7 under Eclipse 3.1 (both GA).
> Any thoughts?
Nothing strange going on like using the "c" prefix more than once?
Is the JSP located somewhere under the parent of your WEB-INF folder
that has the jar files?
- Nitin
_
Nitin Dahyabhai
Re: jsp taglib [message #129194 is a reply to message #129015] |
Tue, 02 August 2005 20:35 |
> folder.
Actually, bug 82333 has one lingering case where we fail to find the
TLD: uris beginning with '/'. Regrettably it wasn't fixed for 0.7.
- Nitin
_
Nitin Dahyabhai
Re: jsp taglib [message #129315 is a reply to message #129280] |
Wed, 03 August 2005 01:36 |
>>>with the taglibs) it does not work and I get lots of yellow underlines
>>>about the
>>>Any thoughts?
It works fine for me, so my only other guess is that there's
something related to how you're including the other file. Does the
file attribute of the include directive begin with a '/'?
- Nitin
_
Nitin Dahyabhai
FUDForum. Page generated in 0.03634 seconds
