Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Emfatic] Detail-less annotations
Re: [Emfatic] Detail-less annotations [message #129455 is a reply to message #129442] |
Wed, 03 September 2008 06:25 |
Originally posted by: sven.efftinge.de
Andy Carpenter schrieb:
> "Ed Merks" <Ed.Merks@gmail.com> wrote in message
> news:g9j9n8$uth$2@build.eclipse.org...
>> Dimitrios,
>> I need to find folks who will actively work on Efmatic. Maybe I can find
>> some time personally. Right now, things have kind of ground to a halt.
>> It does sound like a bug to me so you may as well open a bugzilla...
> I'd be interested in working on Emfatic. If so, long term I'd like to
> re-implement it using TCS (we have a prototype version of this).
> Andy.
Hi Andy,
we (Xtext developers) are also working on an implementation of EMFatic
to show case the features of it.
We thought it would be a good example to be shipped with Xtext, but now
that we need contributors for the EMFatic component, maybe we could work
on it together?
regards,
Sven
Re: [Emfatic] Detail-less annotations [message #129480 is a reply to message #129455] |
Wed, 03 September 2008 08:46 |
Andy Carpenter Messages: 145 Registered: July 2009 |
Hi Sven,
I definitely interested in working with you (and others) on Emfatic
tooling. My motivation is to enable some laboratory exercises for
students where they develop models with invariants/constraints,
generate code from the models and then use the generated code
to validate instance data. This means that I'm more interested in
simplicity than completeness.
The Ecore tools would have worked, but I felt tat they looked too
like UML tools, which would have meant that students would expect
the capabilities of UML. Also all of the details of constraint annotations
must be seen by the students. With Emfatic the short form of
annotation names spaces can be used and the Ecore constraints
annotation can be added in the Ecore model generation step.
So far I have an Emfatic nature and incremental project builder
(implemented as a TCS injection and ATL transformation) that
generates an ecore model version of a valid Emfatic file when
it is saved. This is supported by an Emfatic file creation wizard
that sets the Emfatic nature on the enclosing project, and a
menu item to toggle the Emfatic nature.
The state of support for the Emfatic language is that includes
are not supported, the parsing of generic syntax needs checking,
any instance class name that is not a simple identifier must be put
into quotes and a couple of other minor issues.
How would you like to take any joint work forward?
Andy.
"Sven Efftinge" <sven@efftinge.de> wrote in message
news:g9lakf$nks$1@build.eclipse.org...
>>> Dimitrios,
>>> find some time personally. Right now, things have kind of ground to a
>>> halt. It does sound like a bug to me so you may as well open a
>>> bugzilla...
>> Andy.
> Hi Andy,
> we (Xtext developers) are also working on an implementation of EMFatic to
> on it together?
> regards,
> Sven
Re: [Emfatic] Detail-less annotations [message #129492 is a reply to message #129480] |
Wed, 03 September 2008 13:42 |
Ed Merks Messages: 33141 Registered: July 2009 |
--------------080108000404030404090907
Andy,
Comments below.
Andy Carpenter wrote:
> Hi Sven,
That's cool. Is this current issue holding you up or is just a nit?
I'm very interested in getting more directly involved in this myself.
I'm a bit sick and tired of XML. We could do so much better with
notations focused on ease of human understanding rather than ease of
machine parsing...
Time to change their expectations. :-P
The Ecore Tools editor has quite a nice forms-based design for working
with annotations, though they are kind of tucked away as opposed to
Emfatic, where they are a very visible thing very similar to Java 5.0's
annotations.
The notation is quite nice...
> it is saved.
It would be quite cool if the base EMF frameworks were more content-type
focused such that they could directly process an Emfatic resource to
extract the Ecore from it. Such things should be possible, but will
take some time and effort...
I don't have a good understanding yet of how direct changes to the Ecore
might be feed back to the Emfatic. I wonder if we should be providing
an importer and even an exporter much like we have for UML and XSD...
All the things that were added in EMF 2.3 need attention... That's even
true for the Ecore Tools editor...
That's a very good question. I'd like to get actively involved in this
myself as well. But I don't know much of anything about Xtext yet and I
don't have a good understanding of the current code base. I was hoping
to have time to start on my learning in October when I'll get a chance
to travel to Germany...
Are you patient enough to wait that long? It would be great to have
more interested and active parties...
> Andy.
>>>> Dimitrios,
>>>> bugzilla...
>>> Andy.
>> Hi Andy,
>> on it together?
>> regards,
>> Sven
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Andy,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:g9ljal$ref$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Sven,
</pre>
</blockquote>
machine parsing...<br>
<pre wrap="">
the capabilities of UML.</pre>
</blockquote>
Time to change their expectations. :-P<br>
<pre wrap=""> Also all of the details of constraint annotations
must be seen by the students. </pre>
</blockquote>
annotations.<br>
<pre wrap="">With Emfatic the short form of
</pre>
</blockquote>
The notation is quite nice...<br>
<pre wrap="">
it is saved. </pre>
</blockquote>
content-type focused such that they could directly process an Emfatic
resource to extract the Ecore from it. Such things should be possible,
but will take some time and effort...<br>
<pre wrap="">This is supported by an Emfatic file creation wizard
</pre>
</blockquote>
Ecore might be feed back to the Emfatic. I wonder if we should be
providing an importer and even an exporter much like we have for UML
and XSD...<br>
<pre wrap="">
</pre>
</blockquote>
even true for the Ecore Tools editor...<br>
<pre wrap="">
</pre>
</blockquote>
I don't have a good understanding of the current code base. I was
hoping to have time to start on my learning in October when I'll get a
chance to travel to Germany...<br>
<br>
more interested and active parties...<br>
<pre wrap="">
Andy.
"Sven Efftinge" <a class="moz-txt-link-rfc2396E" href="mailto:sven@efftinge.de"><sven@efftinge.de></a> wrote in message
<a class="moz-txt-link-freetext" href="news:g9lakf$nks$1@build.eclipse.org">news:g9lakf$nks$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Andy Carpenter schrieb:
</pre>
<pre wrap="">"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com"><Ed.Merks@gmail.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:g9j9n8$uth$2@build.eclipse.org">news:g9j9n8$uth$2@build.eclipse.org</a>...
</pre>
<pre wrap="">Dimitrios,
bugzilla...
</pre>
</blockquote>
<pre wrap="">I'd be interested in working on Emfatic. If so, long term I'd like to
Andy.
</pre>
</blockquote>
<pre wrap="">Hi Andy,
on it together?
regards,
Sven
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------080108000404030404090907--
Ed Merks
Re: [Emfatic] Detail-less annotations [message #129516 is a reply to message #129492] |
Wed, 03 September 2008 15:16 |
Hi Ed, hi Andy,
>> it is saved.
With an Xtext implementation a specific ResourceFactory would be
registered, so that you cannot tell whether the format orginally was xmi
or emfatic (besides that the URI has a different file extension, of course).
The Resource implementation generated by Xtext also provides saving
models. So it fully supports the Resource interface.
Yes, this is great. We still need some weeks to fix some things in
Xtext. So October sould be a good starting date.
Sven
Re: [Emfatic] Detail-less annotations [message #129539 is a reply to message #129492] |
Thu, 04 September 2008 09:01 |
news:g9m485$hme$1@build.eclipse.org...
> Andy,
> Comments below.
>> Hi Sven,
> machine parsing...
No I'm not heldup. I now have in place all of the software that
I need for simple student exercises.
> annotations.
Having spent some years working with ISO 10303 STEP EXPRESS,
my preference is for textual input.
>> it is saved.
As I say, I'm not currently heldup. So, yes, I can wait that lon.
>> Andy.
>>>>> Dimitrios,
>>>>> bugzilla...
>>>> Andy.
>>> Hi Andy,
>>> to
>>> on it together?
>>> regards,
>>> Sven
Re: [Emfatic] Detail-less annotations [message #620282 is a reply to message #129321] |
Tue, 02 September 2008 11:57 |
Dimitrios,
halt. It does sound like a bug to me so you may as well open a bugzilla...
Dimitrios Kolovos wrote:
> Any thoughts on this?
> Cheers,
> Dimitrios
>> Hi,
>> The old Emfatic tooling (0.0.2) allowed annotations without details e.g.
>> @ann
>> class X {}
>> The new tooling (CVS version) doesn't allow this any more as the
>> parser complains that it expects a ( - with () it doesn't work either
>> as it expects an identifier after (.
>> I suspect that this is a bug as ECore itself allows detail-less
>> annotations (or at least the ECore editor doesn't complain about them).
>> Cheers,
>> Dimitrios
Ed Merks
Re: [Emfatic] Detail-less annotations [message #620293 is a reply to message #129455] |
Hi Sven,
Andy.
>>> Dimitrios,
>>> bugzilla...
>> Andy.
> Hi Andy,
> on it together?
> regards,
> Sven
Re: [Emfatic] Detail-less annotations [message #620294 is a reply to message #129480] |
Andy,
Comments below.
> Hi Sven,
machine parsing...
annotations.
> it is saved.
> Andy.
>>>> Dimitrios,
>>>> bugzilla...
>>> Andy.
>> Hi Andy,
>> on it together?
>> regards,
>> Sven
<html>
<head>
</head>
Andy,<br>
<br>
Comments below.<br>
<br>
</pre>
</blockquote>
<pre wrap="">
</blockquote>
</blockquote>
annotations.<br>
</pre>
</blockquote>
<pre wrap="">
it is saved. </pre>
</blockquote>
</pre>
</blockquote>
and XSD...<br>
<pre wrap="">
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<br>
<pre wrap="">
Andy.
</pre>
</pre>
</pre>
bugzilla...
</pre>
</blockquote>
Andy.
</pre>
</blockquote>
on it together?
regards,
Sven
</pre>
</blockquote>
</pre>
</blockquote>
</body>
</html>
Ed Merks
Re: [Emfatic] Detail-less annotations [message #620298 is a reply to message #129492] |
> Andy,
> Comments below.
>> Hi Sven,
> machine parsing...
> annotations.
>> it is saved.
>> Andy.
>>>>> Dimitrios,
>>>>> bugzilla...
>>>> Andy.
>>> Hi Andy,
>>> to
>>> on it together?
>>> regards,
>>> Sven
Current Time: Fri Apr 26 05:54:23 GMT 2024
Powered by FUDForum. Page generated in 0.04385 seconds
