Home » Language IDEs » Java Development Tools (JDT) » Clean way of getting fully qualified types of imethod parameters?
Clean way of getting fully qualified types of imethod parameters? [message #935161] Sat, 06 October 2012 15:08 Go to next message
I am trying to get the fully qualified types from an imethod without poking the imports.
Is there a way to resolve "Qzzzz;" into "xxx.yyy.zzz" for Icompilationunit cu?
Do I need to use the IClassFile?
Thanks a lot in advance!!!
Re: Clean way of getting fully qualified types of imethod parameters? [message #936105 is a reply to message #935161] Sun, 07 October 2012 13:42 Go to previous messageGo to next message
I meant the fully qualified names of the parameters in an imethod.
int method1(String s){
getParameterTypes() returns "QString;"
Is there a clean way to turn "QString:" into java.lang.String?
Thanks a sorry for the confusing post
Re: Clean way of getting fully qualified types of imethod parameters? [message #937238 is a reply to message #936105] Mon, 08 October 2012 16:22 Go to previous messageGo to next message
Would attaching source to an IClassFile bring the following out come:
Map the offset of the ICompilationUnit's method to the same method in the IClassFile so when I call
IClassFile.getElementAt(int) using the same offset from the CU returns the same IMethod from the IClassFile?
In the hope that this way IClassFile's IMethod.getParameterTypes() return the fully qualified names of those type
Thanks a lot!
Re: Clean way of getting fully qualified types of imethod parameters? [message #937491 is a reply to message #937238] Mon, 08 October 2012 22:21 Go to previous messageGo to next message
The name must be resolved relative to the declaring class, so from the IMethod fetch the parent IType, from where you can use IType.resolveType(String).
For further inspiration you may want to take a look at the implementation of the (jdt.ui internal) method org.eclipse.jdt.internal.corext.util.JavaModelUtil.getResolvedTypeName(String, IType).
HTH
Stephan
Re: Clean way of getting fully qualified types of imethod parameters? [message #937840 is a reply to message #937491] Tue, 09 October 2012 06:08 Go to previous messageGo to next message
Stephan Herrmann wrote on Mon, 08 October 2012 22:21
HTH
Stephan
"The name must be resolved relative to the declaring class" I supposed it was necessary.
"so from the IMethod fetch the parent IType, from where you can use IType.resolveType(String)"
I swear I tried this but probably with the other things going on I may have messed it up.
"For further inspiration you may want to take a look at the implementation of the (jdt.ui internal) method org.eclipse.jdt.internal.corext.util.JavaModelUtil.getResolvedTypeName(String, IType)."
Thanks for the tip. Will look into it.
Again thanks!
Re: Clean way of getting fully qualified types of imethod parameters? [message #938367 is a reply to message #937491] Tue, 09 October 2012 16:22 Go to previous messageGo to next message
HTH
Stephan
It worked! The trick was to clean the output from getParameterType() which is "Qtype_name;". Once I passed type_name to resolveType, I got the info I needed
Thanks a lot!!
Re: Clean way of getting fully qualified types of imethod parameters? [message #938512 is a reply to message #938367] Tue, 09 October 2012 19:53 Go to previous message
I found a problem. I don't know if it's known.
Say:
public Type1 returnType1(Type1 t){
I can resolve the parameter t when calling the declaring IType resolveType().
But if I call getReturnType() afterwards on the IMethod I get an Exception saying that the return type is not in the correct format (?) I am calling getDeclaringType() just once before calling the mentioned methods
Is this a known problem? I can get around this but I thought about mentioning it.
[Updated on: Tue, 09 October 2012 19:55] by Moderator
Previous Topic:interface implemenation methods with reasonable argument names?
Next Topic:Problems During Content Assist (error on @ completion)
Current Time: Sun Oct 26 09:39:23 EDT 2025
Powered by FUDForum. Page generated in 0.05842 seconds
