Re: BridgeServlet: is not available. [message #956428 is a reply to message #956395] |
Wed, 24 October 2012 13:55 |
Jeremie Bresson Messages: 1252 Registered: October 2011 |
Check the validity of your {{your_project}}.server/products/production/{{project}}-server.product
See my message in this thread for a screenshot (with the location of the validate button).
If a plugin is missing, when you click on validate it will be listed. You should add it to the list.
If you get "No problem were detected", indicate it in the forum: this will tell that the error is where else.
The plugins included when you start the server from Eclipse are defined in the dev product file. The plugins that are included in the war are defined in the production product file.
There is a difference, because when you start from eclipse you run a server with Jetty. When you export a war, you do not need Jetty, because you will deploy in a container (like Tomcat).
[Updated on: Wed, 24 October 2012 13:57] Report message to a moderator
FUDForum. Page generated in 0.05516 seconds
