Home » Modeling » ATL » Stereotypes tag values: setValue to copy tag value(setValue to copy tag value)
Stereotypes tag values: setValue to copy tag value [message #931388] Wed, 03 October 2012 02:32 Go to next message
I'm new with ATL. I'm trying to copy some UML diagrams depending on the stereotypes that have the elements in the model. Everything is fine until I try to copy all the tag values the element may have. I don't find why the target model has no value on its tags. Any idea would be helpful.
helper context UML2!Element def:setTagValue(stereotype:String, tag:String, value:UML2!EObject):UML2!Element=
if(self.getAppliedStereotypes()->select(e|e.name=stereotype)->notEmpty())
then self.setValue(self.getAppliedStereotypes()->select(f|f.name=stereotype)->first(),tag,value)
else OclUndefined
endif;
rule copy{
do{
for(st in s.getAppliedStereotypes()){
t.applyStereotype(st);
thisModule.inStereotype<-st;
for(tag in st.getOwnedAttributes()){
thisModule.inTag<-tag;
t.setTagValue(thisModule.inStereotype.name,thisModule.inTag.name,s.getTagValue(thisModule.inStereotype.name,thisModule.inTag.name))
if I use setTagValue with concrete or specific values, it works fine.
iker
Re: Stereotypes tag values: setValue to copy tag value [message #937046 is a reply to message #931388] Mon, 08 October 2012 11:58 Go to previous messageGo to next message
Hi Iker,
I'm not sure what is wrong there. You can try my version which I have been using for a few years. It is quite similar but a little more robust. The check for the base_ property could be improved though. Anyway it works!
do
--apply all the profile's stereotype values to the target model. they don't get copied by ATL automatically
thisModule.applyStereoTypesValue(false,s,t);
rule applyStereoTypesValue(required : Boolean, s : UML!Element, t : UML!Element)
do
--loop over all the stereotypes on an element
for (stereotype in s.getAppliedStereotypes())
--if the UML!Element does not get its stereotype automically applied (i.e. UML not required) then we must apply it manually
--note:surprisingly the "required" property doesn't seem to be exposed by UML2. maybe look into this more
if (not required)
t.applyStereotype(stereotype);
--loop over all the stereotype's properties
for (property in stereotype.getAllAttributes())
--apply the value if there is one. don't apply the base type property as ATL cannot handle this. also don't touch read-only properties.
if(s.hasValue(stereotype,property.name) and (not property.name.startsWith('base_')) and not property.isReadOnly())
t.setValue(stereotype,property.name,s.getValue(stereotype,property.name));
The comments come for free Smile
Ronan
Re: Stereotypes tag values: setValue to copy tag value [message #938727 is a reply to message #937046] Wed, 10 October 2012 01:21 Go to previous message
Thanks Ronan.
I tried it and it works fine now.I think my version does not work because of the base_property. I didn't realize on that.
Thanks again,
iker.
Previous Topic:ATL ignores elements inside a UML PackageImport
Next Topic:semantic error
Current Time: Tue Sep 23 11:12:42 EDT 2025
Powered by FUDForum. Page generated in 1.03668 seconds
