Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Integrate EMF Compare in Subversion
Integrate EMF Compare in Subversion [message #126975] Thu, 10 July 2008 05:00 Go to next message
Originally posted by: schlichtomat.gmx.de
Hi! I got a question and it would be great if anyone could help me out
with this one: Is there a way to use EMF Compare as differencing and merge
tool in subversion? I did not find anything in the web, yet. I'm wondering
if this would be useful (this is what I think) and if so, I'm looking for
an existing integration.
Re: Integrate EMF Compare in Subversion [message #127013 is a reply to message #126975] Thu, 10 July 2008 05:47 Go to previous messageGo to next message
Hi Marco,
EMF compare is, indeed, already integrated with Subversion if you're using a an plugin providing Eclipse integration with Subversion (aka Subversive or Subclipse). That means for instance that comparing models with the team repository should trigger EMF Compare.
We even have a specific plugin for Subversive correcting a few issues we had at some time but as we are not sure yet if it's an issue from our side or from the subversive implementation we did not build this plugin yet and it's only available on the Eclipse modeling CVS.
Anyway installing an SVN plugin + EMF compare should work fine, please tell us if you encounter issues.
Cédric
Re: Integrate EMF Compare in Subversion [message #130214 is a reply to message #127013] Thu, 16 October 2008 12:34 Go to previous messageGo to next message
Originally posted by: sramasamy.ifmc.sdps.org
I've verified that EMF Compare works when comparing workspace .ecore
files against those stored in subversion.
But when I attempt to compare a workspace .genmodel file against that in
subversion I get several NPE. I'm using subclipse 1.4.5 with EMF Compare
0.8.1. If I compare the two .genmodel files stored in my workspace I
don't get these NPEs.
Here is the stack trace:
!ENTRY org.eclipse.jface 4 2 2008-10-16 11:29:47.484
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
org.eclipse.emf.codegen.ecore.genmodel.impl.GenDataTypeImpl. getQualifiedInstanceClassName(GenDataTypeImpl.java:212)
org.eclipse.emf.codegen.ecore.genmodel.provider.GenDataTypeI temProvider.getText(GenDataTypeItemProvider.java:120)
org.eclipse.emf.edit.ui.provider.AdapterFactoryLabelProvider .getText(AdapterFactoryLabelProvider.java:374)
org.eclipse.jface.viewers.WrappedViewerLabelProvider.getText (WrappedViewerLabelProvider.java:108)
org.eclipse.jface.viewers.WrappedViewerLabelProvider.update( WrappedViewerLabelProvider.java:164)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:145)
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:932)
org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:102)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:1012)
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:466)
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:2041)
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:827)
org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:802)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:776)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:634)
org.eclipse.jface.viewers.AbstractTreeViewer.internalExpandT oLevel(AbstractTreeViewer.java:1702)
org.eclipse.jface.viewers.AbstractTreeViewer.internalExpandT oLevel(AbstractTreeViewer.java:1712)
org.eclipse.jface.viewers.AbstractTreeViewer.expandToLevel(A bstractTreeViewer.java:1054)
org.eclipse.jface.viewers.AbstractTreeViewer.expandToLevel(A bstractTreeViewer.java:1035)
org.eclipse.jface.viewers.AbstractTreeViewer.expandAll(Abstr actTreeViewer.java:1024)
org.eclipse.emf.compare.ui.viewer.content.part.diff.ModelCon tentMergeDiffTab.inputChanged(ModelContentMergeDiffTab.java: 364)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:251)
org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1603)
org.eclipse.emf.compare.ui.viewer.content.part.diff.ModelCon tentMergeDiffTab.setReflectiveInput(ModelContentMergeDiffTab .java:278)
org.eclipse.emf.compare.ui.viewer.content.part.ModelContentM ergeTabFolder.setInput(ModelContentMergeTabFolder.java:310)
org.eclipse.emf.compare.ui.viewer.content.ModelContentMergeV iewer.updateContent(ModelContentMergeViewer.java:675)
org.eclipse.compare.contentmergeviewer.ContentMergeViewer.in ternalRefresh(ContentMergeViewer.java:715)
org.eclipse.compare.contentmergeviewer.ContentMergeViewer.in putChanged(ContentMergeViewer.java:615)
org.eclipse.emf.compare.ui.viewer.content.ModelContentMergeV iewer.setInput(ModelContentMergeViewer.java:281)
org.eclipse.compare.CompareViewerSwitchingPane.setInput(Comp areViewerSwitchingPane.java:256)
org.eclipse.compare.CompareEditorInput.internalSetContentPan eInput(CompareEditorInput.java:791)
org.eclipse.compare.CompareEditorInput.access$7(CompareEdito rInput.java:789)
org.eclipse.compare.CompareEditorInput$13.run(CompareEditorI nput.java:729)
org.eclipse.compare.CompareEditorInput.feed1(CompareEditorIn put.java:723)
org.eclipse.compare.CompareEditorInput.feedInput(CompareEdit orInput.java:701)
org.eclipse.compare.CompareEditorInput.createContents(Compar eEditorInput.java:524)
org.eclipse.compare.internal.CompareEditor.createCompareCont rol(CompareEditor.java:415)
org.eclipse.compare.internal.CompareEditor.createPartControl (CompareEditor.java:379)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:266)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2820)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2729)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2721)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2673)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2652)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2635)
org.eclipse.compare.internal.CompareUIPlugin$1.run(CompareUI Plugin.java:454)
org.eclipse.compare.internal.CompareUIPlugin.syncExec(Compar eUIPlugin.java:1171)
org.eclipse.compare.internal.CompareUIPlugin.internalOpenEdi tor(CompareUIPlugin.java:465)
org.eclipse.compare.internal.CompareUIPlugin.openCompareEdit or(CompareUIPlugin.java:429)
org.eclipse.compare.CompareUI.openCompareEditorOnPage(Compar eUI.java:135)
org.tigris.subversion.subclipse.ui.actions.CompareWithRemote Action$1.run(CompareWithRemoteAction.java:57)
org.tigris.subversion.subclipse.ui.repository.RepositoryMana ger.run(RepositoryManager.java:375)
org.tigris.subversion.subclipse.ui.actions.SVNAction$1.run(S VNAction.java:226)
org.tigris.subversion.subclipse.ui.actions.SVNAction$2.run(S VNAction.java:235)
org.tigris.subversion.subclipse.ui.actions.SVNAction.run(SVN Action.java:232)
org.tigris.subversion.subclipse.ui.actions.CompareWithRemote Action.execute(CompareWithRemoteAction.java:53)
org.tigris.subversion.subclipse.ui.actions.SVNAction.run(SVN Action.java:56)
org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDel egate.java:70)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:241)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
!ENTRY org.eclipse.jface 4 2 2008-10-16 11:29:47.703
!STACK 0
!ENTRY org.eclipse.jface 4 2 2008-10-16 11:29:47.781
!STACK 0
Cédric Brun wrote:
> Hi Marco,
> Cédric
Re: Integrate EMF Compare in Subversion [message #130229 is a reply to message #130214] Thu, 16 October 2008 15:19 Go to previous messageGo to next message
I just noticed that this bug occurs when you compare a genmodel file
even with it's local history. So this may rule out any issue with
Suversion/Subclipe and place the issue in the Eclipse file versioning
code. This is verified on Eclipse 3.4.1
-sud
> !STACK 0
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Cédric Brun wrote:
>> Hi Marco,
>> Cédric
>>> merge
>>> wondering
>>> for
Re: Integrate EMF Compare in Subversion [message #130267 is a reply to message #130229] Fri, 17 October 2008 03:37 Go to previous messageGo to next message
--------------040202060309030609060007
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Sudhakar,
We've has many issues with the genmodel comparison ... something must be
wrong in the way we load it. Can you fill a bug with your stack trace so
that we remember this has to be fixed?
Laurent Goubet
Obeo
> -sud
>> in subversion I get several NPE. I'm using subclipse 1.4.5 with EMF
>> Compare 0.8.1. If I compare the two .genmodel files stored in my
>> workspace I don't get these NPEs.
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Cédric Brun wrote:
>>> Hi Marco,
>>> Cédric
>>>> merge
>>>> wondering
>>>> looking for
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyLyI+T2JlbzwvYT4NCmVtYWls O2ludGVybmV0
OmxhdXJlbnQuZ291YmV0QG9iZW8uZnINCnVybDpodHRwOi8vd3d3Lm9iZW8u ZnINCnZlcnNp
b246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------040202060309030609060007--
Re: Integrate EMF Compare in Subversion [message #130354 is a reply to message #130267] Mon, 20 October 2008 15:14 Go to previous messageGo to next message
Logged bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=251456
-sud
laurent Goubet wrote:
> Hi Sudhakar,
> Laurent Goubet
> Obeo
>> -sud
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Cédric Brun wrote:
>>>> Hi Marco,
>>>> modeling CVS.
>>>> Cédric
>>>>> and merge
>>>>> wondering
>>>>> looking for
Re: Integrate EMF Compare in Subversion [message #130370 is a reply to message #130354] Tue, 21 October 2008 03:14 Go to previous message
--------------010104010006050808000702
Thanks Sudhakar,
We'll try to handle this issue asap.
Laurent Goubet
Obeo
Sudhakar a écrit :
> Logged bug
> Thanks
> -sud
>> Hi Sudhakar,
>> be wrong in the way we load it. Can you fill a bug with your stack
>> trace so that we remember this has to be fixed?
>> Laurent Goubet
>> Obeo
>>> -sud
>>>> that in subversion I get several NPE. I'm using subclipse 1.4.5 with
>>>> EMF Compare 0.8.1. If I compare the two .genmodel files stored in my
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Cédric Brun wrote:
>>>>> Hi Marco,
>>>>> Compare.
>>>>> modeling CVS.
>>>>> Cédric
>>>>>> out
>>>>>> and merge
>>>>>> wondering
>>>>>> looking for
--------------010104010006050808000702--
Re: Integrate EMF Compare in Subversion [message #619375 is a reply to message #126975] Thu, 10 July 2008 05:47 Go to previous message
Hi Marco,
Cédric
Re: Integrate EMF Compare in Subversion [message #620351 is a reply to message #127013] Thu, 16 October 2008 12:34 Go to previous message
!STACK 0
!STACK 0
!STACK 0
Cédric Brun wrote:
> Hi Marco,
> Cédric
Re: Integrate EMF Compare in Subversion [message #620352 is a reply to message #130214] Thu, 16 October 2008 15:19 Go to previous message
-sud
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Cédric Brun wrote:
>> Hi Marco,
>> Cédric
>>> merge
>>> wondering
>>> for
Re: Integrate EMF Compare in Subversion [message #620355 is a reply to message #130229] Fri, 17 October 2008 03:37 Go to previous message
Hi Sudhakar,
Laurent Goubet
Obeo
> -sud
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Cédric Brun wrote:
>>> Hi Marco,
>>> Cédric
>>>> merge
>>>> wondering
>>>> looking for
Re: Integrate EMF Compare in Subversion [message #620362 is a reply to message #130267] Mon, 20 October 2008 15:14 Go to previous message
Logged bug
-sud
> Hi Sudhakar,
> Laurent Goubet
> Obeo
>> -sud
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Cédric Brun wrote:
>>>> Hi Marco,
>>>> modeling CVS.
>>>> Cédric
>>>>> and merge
>>>>> wondering
>>>>> looking for
Re: Integrate EMF Compare in Subversion [message #620363 is a reply to message #130354] Tue, 21 October 2008 03:14 Go to previous message
Thanks Sudhakar,
Laurent Goubet
Obeo
Sudhakar a écrit :
> Logged bug
> Thanks
> -sud
>> Hi Sudhakar,
>> Laurent Goubet
>> Obeo
>>> -sud
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Cédric Brun wrote:
>>>>> Hi Marco,
>>>>> Compare.
>>>>> modeling CVS.
>>>>> Cédric
>>>>>> out
>>>>>> and merge
>>>>>> wondering
>>>>>> looking for
Previous Topic:[Tenco] library editor tutorial
Next Topic:Setting up dev env for Teneo Hibernate
Current Time: Mon Nov 03 16:03:32 EST 2025
Powered by FUDForum. Page generated in 0.05691 seconds
