Re: how to get the reachable objects from an EObject [message #929898 is a reply to message #929864] |
Mon, 01 October 2012 21:37 |
Hi, Junior,
Have a look at the implementation of getChoiceOfValues() in the
ItemPropertyDescriptorWithUniqueChoiceOfValueLabels inner class in the
EModelElementItemProvider for an example.
Christian
On 2012-10-01 20:55:55 +0000, Junior Lekane Nimpa said:
> Hello everyone,
> i am quite new to EMF and i want to implement a property sheet to
> display some properties of EObjects. Actually i am facing a problem. I
> want to display all types that an ETypedElement can take as value. But
> i don't know how to get all those reachable types.
> Can someone help me?
> Any help would be really appreciate
> regards
> Junior
Re: how to get the reachable objects from an EObject [message #934016 is a reply to message #929898] |
Fri, 05 October 2012 15:10 |
Junior Lekane Nimpa Messages: 23 Registered: September 2012 |
Hello ,
Thanks christian for your reply. I had a look at the implementation of getChoicesOfValues, but since i am new to EMF, i could not get smart.
Basically, my problem is as follows.
I am implementing property sheet pages to visualize some properties of EObjects
and i want to user to be able to set the eType of a selected ETypedElement in an advanced property sheet. To do this, i use a ComboBoxViewerCellEditor.
But i don't know what should be the input of the cellEditor, so that it display for example the following:
EBoolean
EChar
EString
I tried the following:
ComboBoxViewerCellEditor.setInput(EcorePackage.Literals.ECLASSIFIER);
But i only get the attributes of the MetaObject EClassifier displayed.
I also tried the following
IItemPropertyDescriptor descriptor = new ItemPropertyDescriptor(new EcoreItemProviderAdapterFactory(),null,null,EcorePackage.Literals.ETYPED_ELEMENT__ETYPE);
result = descriptor.getChoiceOfValues(typedElement);
i only get the classes that are contained in my .ecore file.
But how do i get all predefined types like EBoolean,EString,... and all classes, that are contained in my .ecore file together as input of the ComboBoxViewerCellEditor?
Any hint and/or answer is really welcome
Junior
Re: how to get the reachable objects from an EObject [message #934799 is a reply to message #934016] |
Sat, 06 October 2012 09:56 |
Ed Merks Messages: 33142 Registered: July 2009 |
You'd need a content provider and a label provider for that; the
contents presumably will be computed by the content produced by the
content provider.
What you'll want is very similar to
org.eclipse.emf.ecore.provider.ETypedElementItemProvider.addETypePropertyDescriptor(...).new
ItemPropertyDescriptorWithUniqueChoiceOfValueLabels()
{...}.getChoiceOfValues(Object)
If you have an ETypedElement why don't get use
EcoreItemProviderAdapterFactory to get an adapter for
IItemPropertySource and then
org.eclipse.emf.edit.provider.IItemPropertySource.getPropertyDescriptor(Object,
Object) to get the property descriptor (the second argument should be
EcorePackage.Literals.ETYPED_ELEMENT__ETYPE) from which you can call
getChoiceOfValues. If you use EMF's content and label providers in the
cell editor, you can use
org.eclipse.emf.edit.provider.ItemProvider.ItemProvider(Collection<?>)
to create an input object that will list these choices.
On 05/10/2012 5:10 PM, Junior Lekane Nimpa wrote:
> Hello ,
> EObjects
> ComboBoxViewerCellEditor. But i don't know what should be the input of
> EBoolean
> EChar
> EString
> Regards
> Junior
Ed Merks
FUDForum. Page generated in 0.03120 seconds
