Java-Version of WAR product [message #929099] |
Mon, 01 October 2012 08:10 |
S. Schulz Messages: 72 Registered: September 2011 |
Member |
Hi everyone!
I've got a problem concerning the creation of a WAR. I created it using a warproduct-file, but when I deploy it, I get the following message:
java.lang.Error: Unresolved compilation problem:
'<>' operator is not allowed for source level below 1.7
I took a look at the class-file with the error, and instead of compiled code it just contains the stack trace of above exception. Then I checked the plug-in in question: Both the build path and the manifest state it's a Java 7 project.
So my question is: Why would the WAR product export wizard assume the project to be anything other than a Java 7 project? How do I change it? And is there a way to tell the export wizard to just show an error message and stop exporting when a error like this happens, instead of ignoring it?
Thanks in advance,
S. Schulz
Re: Java-Version of WAR product [message #931521 is a reply to message #929099] |
Wed, 03 October 2012 09:26 |
Ivan Furnadjiev Messages: 2427 Registered: July 2009 Location: Sofia, Bulgaria |
check your project properties - "Java Compiler" settings. What are your
"JDK Compliance" settings?
Best,
Ivan
On 10/1/2012 11:10 AM, S. Schulz wrote:
> Hi everyone!
> message:
> java.lang.Error: Unresolved compilation problem: '<>' operator is
> ignoring it?
> Thanks in advance,
> S. Schulz
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Java-Version of WAR product [message #934125 is a reply to message #933664] |
Fri, 05 October 2012 17:26 |
I verified that PDE and the WAR Product Tooling are able to build plugins using Java 7 source.
I think you are probably missing the OSGi Execution Environment. Open the plugin's manifest editor and verify that JavaSE-1.7 is listed under Execution Environments like this:
With JavaSE-1.7 listed there it was able to build properly, but when I removed it the build failed with the same error you described.
Hope that helps,
Cole
FUDForum. Page generated in 0.04910 seconds
