Re: NullPointerException in Tomcat [message #127305 is a reply to message #126769] |
Mon, 06 April 2009 10:18 |
Hi Anton,
we don't use web tools here, so we cannot advise with this case. But I
agree with Ivan, you should start with a normal war file deployment.
Then you can see what is needed and can mimic the contents of the war
file in your web tools project.
> [1]
> http://eclipsesource.com/blogs/2007/12/07/rap-deployment-par t-2-deploying-your-application-as-a-war-file/
I'd rather suggest that you refer to the RAP Help with has an chapter on
war deployment, too. It's included in your Eclipse IDE if you have RAP
Tooling installed. The help is more up to date and the blog post above
contains an approach that is not recommendable from our point of view.
Next thing you should do is get an OSGi console (enable -console in your
web.xml) and see which bundles are installed and active.
Best regards, Ralf
FUDForum. Page generated in 0.05190 seconds
