Re: Hibernate flush causes transactional domain error [message #126194 is a reply to message #126180] |
Tue, 24 June 2008 05:10 |
Hi Manfred,
Are you using a sessioncontroller?
Because if not then hibernateresource sets the flush mode on manual as a default (at least in my
version). Then the flush should only occur in resource.save.
Can you check if you version has this, see the HibernateResource.getSessionWrapper method, there
should be a call to sessionwrapper.setFlushModeManual.
gr. Martin
Manfred Hahn wrote:
> Hi Martin,
> I use the Eclipse 3.3 with the teneo version 0.8.0.v200805200858. My
> actual problem in a GMF application is the auto flush of hibernate.
> During a HibernatePersistabeElist.doLoad() a session is opened. With the
> close of this session a hibernate flush occures. The database creates a
> new key for a new persisted object. This key should be set into the
> model but there is no actual transaction open in the Transactional
> Editing Domain. So I get the following exception:
> java.lang.IllegalStateException: Cannot modify resource set without a
> write transaction
> at
> org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ssertWriting(TransactionChangeRecorder.java:322)
> at
> org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ppendNotification(TransactionChangeRecorder.java:284)
> at
> org.eclipse.emf.transaction.impl.TransactionChangeRecorder.p rocessObjectNotification(TransactionChangeRecorder.java:266)
> at
> org.eclipse.emf.transaction.impl.TransactionChangeRecorder.n otifyChanged(TransactionChangeRecorder.java:222)
> at
> org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:247)
> at
> de.edvchl.clic.workflow.datenabfrage.impl.DatabaseSyncObject Impl.setLogicKey(DatabaseSyncObjectImpl.java:172)
> at
> de.edvchl.clic.workflow.datenabfrage.impl.DatabaseSyncObject Impl.eSet(DatabaseSyncObjectImpl.java:290)
> at
> de.edvchl.clic.workflow.ausdruck.impl.AusdruckImpl.eSet(Ausd ruckImpl.java:189)
> at
> de.edvchl.clic.workflow.ausdruck.impl.KomplexerAusdruckImpl. eSet(KomplexerAusdruckImpl.java:364)
> at
> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1061)
> at
> org.eclipse.emf.teneo.hibernate.mapping.property.EAttributeP ropertyHandler.set(EAttributePropertyHandler.java:187)
> at
> org.hibernate.tuple.entity.AbstractEntityTuplizer.setIdentif ier(AbstractEntityTuplizer.java:211)
> at
> org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer.setIden tifier(EMFTuplizer.java:116)
> at
> org.hibernate.persister.entity.AbstractEntityPersister.setId entifier(AbstractEntityPersister.java:3596)
> at
> org.hibernate.event.def.AbstractSaveEventListener.performSav e(AbstractSaveEventListener.java:171)
> at
> org.hibernate.event.def.AbstractSaveEventListener.saveWithGe neratedId(AbstractSaveEventListener.java:121)
> at
> org.hibernate.event.def.DefaultSaveOrUpdateEventListener.sav eWithGeneratedOrRequestedId(DefaultSaveOrUpdateEventListener .java:187)
> at
> org.hibernate.event.def.DefaultSaveOrUpdateEventListener.ent ityIsTransient(DefaultSaveOrUpdateEventListener.java:172)
> at
> org.hibernate.event.def.DefaultSaveOrUpdateEventListener.per formSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:94)
> at
> org.hibernate.event.def.DefaultSaveOrUpdateEventListener.onS aveOrUpdate(DefaultSaveOrUpdateEventListener.java:70)
> at
> org.hibernate.impl.SessionImpl.fireSaveOrUpdate(SessionImpl. java:507)
> at org.hibernate.impl.SessionImpl.saveOrUpdate(SessionImpl.java :499)
> at
> org.hibernate.engine.CascadingAction$5.cascade(CascadingActi on.java:218)
> at org.hibernate.engine.Cascade.cascadeToOne(Cascade.java:268)
> at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java :216)
> at org.hibernate.engine.Cascade.cascadeProperty(Cascade.java:16 9)
> at org.hibernate.engine.Cascade.cascade(Cascade.java:130)
> at
> org.hibernate.event.def.AbstractFlushingEventListener.cascad eOnFlush(AbstractFlushingEventListener.java:131)
> at
> org.hibernate.event.def.AbstractFlushingEventListener.prepar eEntityFlushes(AbstractFlushingEventListener.java:122)
> at
> org.hibernate.event.def.AbstractFlushingEventListener.flushE verythingToExecutions(AbstractFlushingEventListener.java:65)
> at
> org.hibernate.event.def.DefaultFlushEventListener.onFlush(De faultFlushEventListener.java:26)
> at org.hibernate.impl.SessionImpl.flush(SessionImpl.java:1000)
> at org.hibernate.impl.SessionImpl.managedFlush(SessionImpl.java :338)
> at
> org.hibernate.transaction.JDBCTransaction.commit(JDBCTransac tion.java:106)
> at
> org.eclipse.emf.teneo.hibernate.HbSessionWrapper.commitTrans action(HbSessionWrapper.java:82)
> at
> org.eclipse.emf.teneo.hibernate.mapping.elist.HibernatePersi stableEList.doLoad(HibernatePersistableEList.java:181)
> at
> org.eclipse.emf.teneo.mapping.elist.PersistableEList.load(Pe rsistableEList.java:207)
> at
> org.eclipse.emf.teneo.mapping.elist.PersistableEList.delegat eSize(PersistableEList.java:443)
> at
> org.eclipse.emf.common.util.DelegatingEList.size(DelegatingE List.java:222)
> at
> org.eclipse.emf.common.util.DelegatingEList$EIterator.hasNex t(DelegatingEList.java:1048)
> at
> org.eclipse.emf.edit.provider.AdapterFactoryItemDelegator.ge tText(AdapterFactoryItemDelegator.java:69)
> at
> org.eclipse.emf.edit.provider.ItemPropertyDescriptor$ItemDel egator.getText(ItemPropertyDescriptor.java:201)
> at
> org.eclipse.emf.edit.ui.provider.PropertyDescriptor$1.getTex t(PropertyDescriptor.java:123)
> at
> org.eclipse.gmf.runtime.emf.ui.properties.sections.PropertyS heetEntry.getValueAsString(PropertySheetEntry.java:457)
> at
> org.eclipse.ui.views.properties.PropertySheetViewer.updateEn try(PropertySheetViewer.java:1335)
> at
> org.eclipse.ui.views.properties.PropertySheetViewer.access$4 (PropertySheetViewer.java:1326)
> at
> org.eclipse.ui.views.properties.PropertySheetViewer$3.valueC hanged(PropertySheetViewer.java:335)
> at
> org.eclipse.gmf.runtime.emf.ui.properties.sections.PropertyS heetEntry.fireValueChanged(PropertySheetEntry.java:316)
> at
> org.eclipse.gmf.runtime.emf.ui.properties.sections.PropertyS heetEntry.setValues(PropertySheetEntry.java:730)
> I know that I can change the default behavior of the hibernate flush
> with the FlushMode, but this time I do not have control over the
> session, it is managed by teneo. And since the auto flush occures on the
> backstage I don't know where to set the Editing Domain Transaction.
> Do you have any advice how to handle this situation?
> greetings from
> Manfred
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Hibernate flush causes transactional domain error [message #619282 is a reply to message #126180] |
Hi Manfred,
gr. Martin
Manfred Hahn wrote:
> Hi Martin,
> write transaction
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> greetings from
> Manfred
The Netherlands
FUDForum. Page generated in 0.03085 seconds
