Home » Eclipse Projects » Equinox » [P2] How to make P2 re-read dropins?
[P2] How to make P2 re-read dropins? [message #126050] Fri, 20 February 2009 09:27 Go to next message
Simple question: How can I force p2 to reread the contents of the dropins
directory after deleting/adding plugins?
A. Digulla
Re: [P2] How to make P2 re-read dropins? [message #126126 is a reply to message #126050] Fri, 20 February 2009 10:38 Go to previous messageGo to next message
Apparently the answer is to reinstall Eclipse:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=265655 :(
Re: [P2] How to make P2 re-read dropins? [message #126165 is a reply to message #126126] Fri, 20 February 2009 15:30 Go to previous messageGo to next message
there are some other ways ;-)
normally eclipse should see new bundles from dropins,
but I know some situations happen where it fails
then here's a workaround
example:
dropins/xyz1/eclipse/plugins
now you want to change plugins from your xyz1
remove xyz1 folder from dropins folder
restart eclipse with -clean
stop eclipse
now add the new version of xyz, but rename the folder !
dropins/xyz2/eclipse/plugins
restart eclipse
all is fine
ekke
Re: [P2] How to make P2 re-read dropins? [message #126229 is a reply to message #126165] Mon, 23 February 2009 04:00 Go to previous message
>[install plugins again with a new folder name under dropins]
Does that work even when the version of the plugin hasn't changed?
A. Digulla
Previous Topic:3.2 to 3.4 migration
Next Topic:Eclipse Equinox out of IDE
Current Time: Fri Sep 26 13:47:41 EDT 2025
Powered by FUDForum. Page generated in 0.04402 seconds
