Home » Language IDEs » C / C++ IDE (CDT) » MAKE runns in STATUS_ACCESS_VIOLATION
MAKE runns in STATUS_ACCESS_VIOLATION [message #125835] Thu, 04 November 2004 05:45 Go to next message
Originally posted by: eclipse.isource.de
"Hello World\n",
i have installed cde and mingw (i also tried using cygwin, but this
did not work with sdl (libsdl.org)).
When i try to compile my project i get the following output on the console:
**** Incremental build of configuration Debug for project Viewer ****
make -k all
0 [main] make 4068 handle_exceptions: Exception:
444 [main] make 4068 open_stackdumpfile: Dumping stack trace to
make.exe.stackdump
Build complete for project Viewer
when i execute "make -k all" from the command line (cmd) everything works
fine.
Grz,
Florian
Re: MAKE runns in STATUS_ACCESS_VIOLATION [message #125900 is a reply to message #125835] Thu, 04 November 2004 10:17 Go to previous messageGo to next message
Florian,
Are running the make that ships as part of Mingw or the make that ships
with Msys? I have seen the type of problem you are describing when using
the Win32 variant of make in the CMD shell. I have had little success
with that combination, so I would strongly suggest getting Msys if you
plan on doing a lot of work with Mingw and CDT.
Florian Liefers wrote:
> "Hello World\n",
> make -k all 0 [main] make 4068 handle_exceptions: Exception:
> make.exe.stackdump
> works fine.
> Grz,
> Florian
Re: MAKE runns in STATUS_ACCESS_VIOLATION [message #125926 is a reply to message #125900] Thu, 04 November 2004 11:29 Go to previous messageGo to next message
> ships with Msys? I have seen the type of problem you are describing
> when using the Win32 variant of make in the CMD shell. I have had
> little success with that combination, so I would strongly suggest
> getting Msys if you plan on doing a lot of work with Mingw and CDT.
Alas, Sean. This feature works on Cygwin also. I cannot reliably reproduce
the error. Sometimes restarting Eclipse does the trick, sometimes I even had
to reboot my machine.
Joost Kraaijeveld
Askesis B.V.
Molukkenstraat 14
6524NB Nijmegen
tel: 024-3888063 / 06-51855277
fax: 024-3608416
e-mail: J.Kraaijeveld@Askesis.nl
web: www.askesis.nl
Re: MAKE runns in STATUS_ACCESS_VIOLATION [message #126067 is a reply to message #125900] Thu, 04 November 2004 21:13 Go to previous messageGo to next message
Sean Evoy wrote:
> Florian,
Yes, i'm using Mingw with Msys and the make command is called from the
Msys/bin directory. In MinGW/bin the make command is named mingw32-make.exe
Grz,
Florian
Re: MAKE runns in STATUS_ACCESS_VIOLATION [message #126255 is a reply to message #125926] Sun, 07 November 2004 11:30 Go to previous messageGo to next message
I have the same experience. Closing and reopening Eclipse is always the
solution for me.
I have the problem when i switch the build configurations from debug to
release.
I use msys.
Ciao
Romano
Re: MAKE runns in STATUS_ACCESS_VIOLATION [message #126306 is a reply to message #126067] Mon, 08 November 2004 04:18 Go to previous messageGo to next message
> Sean Evoy wrote:
>> Florian,
> Grz,
> Florian
I had the same problem with both of them. mingw32-make.exe and make.exe in
msys/bin.
I recompiled make-3.80.1 from its sources. And now i have no problem.
CC Vural
Re: MAKE runns in STATUS_ACCESS_VIOLATION [message #126355 is a reply to message #126306] Mon, 08 November 2004 11:32 Go to previous message
> msys/bin.
Heureka! Today i also fixed the problem!!!!!!
My installation is mingw and msys.
- i renamed the make.exe from msys/bin to make.exe.old (removed it)
- then i copied mingw/bin/mingw32-make.exe to mingw/bin/make.exe
and it works....
Thank you for your inspiration!!! :o)
Grz,
Florian
Previous Topic:exclude paths from indexer
Next Topic:Newbie - remote compile and debug
Current Time: Fri Sep 26 03:26:41 EDT 2025
Powered by FUDForum. Page generated in 0.06084 seconds
