Home » Archived » EPF » Mac OS X support
Mac OS X support [message #11517] |
Mon, 29 May 2006 14:21  |
I read through the development plan on the project web site. I didn't
see anything ruling out (or in) support for Mac OS X. Right now,
though, only Linux/GTK and Windows builds are posted to the download
section. Is there work planned or underway to begin building for OS X
as well? And/or is a helping hand needed there?
I did try creating a build environment and running EPF on my Powerbook.
I checked out the R1_0_M3_BRANCH. I only got as far as trying to
create a new method library. At that point, I got an error dialog, saying:
"IUPL0300E: Unable to open the specified method library.
Reason:
The selected method library folder is invalid, does not exist, or you do
not have the proper permission to access it.
Click OK to select another library folder."
I went and looked at the directory in which it attempted to create the
library; it exists, is empty, and I have read/write/execute permissions
on it.
The following exception was logged to the console.
MultiFileResourceSetImpl.cleanUp(): removed resources: []
org.eclipse.epf.persistence.MultiFileIOException: Could not rename
'/tmp/EPF/_di6kcO8-Edql0tBiwE3BCwnew_diJvcO8-Edql0tBiwE3BCw' to
'/Users/jhoward/EPF/Method Libraries/BUP/library.xmi'
org.eclipse.epf.persistence.MultiFileXMIResourceImpl.commit( MultiFileXMIResourceImpl.java:915)
org.eclipse.epf.persistence.MethodLibraryPersister$FailSafeP ersister.commit(MethodLibraryPersister.java:648)
org.eclipse.epf.persistence.MultiFileResourceSetImpl.save(Mu ltiFileResourceSetImpl.java:1100)
org.eclipse.epf.persistence.MultiFileResourceSetImpl.save(Mu ltiFileResourceSetImpl.java:979)
org.eclipse.epf.library.util.ModelStorage.newLibrary(ModelSt orage.java:71)
org.eclipse.epf.library.services.LibraryProcessor.newLibrary (LibraryProcessor.java:934)
org.eclipse.epf.library.ui.LibraryUIManager.createLibrary(Li braryUIManager.java:346)
org.eclipse.epf.library.ui.LibraryUIManager.promptForMethodL ibrary(LibraryUIManager.java:168)
org.eclipse.epf.authoring.ui.AuthoringUIPlugin.start(Authori ngUIPlugin.java:71)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:995)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:989)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:86)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:409)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:339)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:388)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:352)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
org.eclipse.epf.rcp.MainWorkbenchAdvisor.getInitialWindowPer spectiveId(MainWorkbenchAdvisor.java:115)
org.eclipse.ui.internal.Workbench.getDefaultPerspectiveId(Wo rkbench.java:2351)
org.eclipse.ui.internal.registry.PerspectiveRegistry.verifyD efaultPerspective(PerspectiveRegistry.java:625)
org.eclipse.ui.internal.registry.PerspectiveRegistry.load(Pe rspectiveRegistry.java:405)
org.eclipse.ui.internal.WorkbenchPlugin.getPerspectiveRegist ry(WorkbenchPlugin.java:438)
org.eclipse.ui.internal.Workbench.getPerspectiveRegistry(Wor kbench.java:952)
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1438)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1388)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:190)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:708)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1085)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1847)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.epf.rcp.MainApplication.run(MainApplication.java :52)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
I'm happy to RTFM if someone can point me at the right manual. Any idea
where I might've gone wrong?
Thank you,
Jeffrey
Re: Mac OS X support [message #11558 is a reply to message #11517] |
Mon, 29 May 2006 15:28   |
I believe I have a little more information on the exception from the
post below. I believe the problem is the call to File.renameTo() a few
lines before the exception is thrown. It seems that on some platforms,
renameTo has problems moving files across partitions. In my case, the
/tmp directory is on a different partition than the /Users directory, so
renameTo gives up and returns false.
I hope I'm not overstepping my bounds here, but I created a bugzilla
entry for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=144296
Jeffrey
Jeffrey Howard wrote:
> Hello,
> Reason:
> on it.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter..java:86)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thank you,
> Jeffrey
Re: Mac OS X support [message #11790 is a reply to message #11558] |
Wed, 31 May 2006 19:58   |
Hi Jeffery.
You are doing the right things. OS X is not currently on the project
map. This does not prevent you and other OS X users from making and
submitting the needed changes as patches through Bugzilla. You can also
create your own OS X build for other community members to try. If there
is enough community interest for an OS X build of EPF Composer, the team
might pick it up and make it an officially supported platform.
I would like to have EPF Composer on my PowerBook as well. :)
Jim
> entry for this:
> Jeffrey
>> Hello,
>> Powerbook. I checked out the R1_0_M3_BRANCH. I only got as far as
>> trying to create a new method library. At that point, I got an error
>> dialog, saying:
>> Reason:
>> do not have the proper permission to access it.
>> permissions on it.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> idea where I might've gone wrong?
>> Thank you,
>> Jeffrey
Re: Mac OS X support [message #22287 is a reply to message #11517] |
Sun, 05 November 2006 15:01  |
Originally posted by: jsnit.jnsit.com
Jeffrey,
where you able to run EPF in mac os X. Could you please help me and
probably other mac os X users on that?
Re: Mac OS X support [message #563442 is a reply to message #11517] |
entry for this:
Jeffrey
> Hello,
> Reason:
> on it.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thank you,
> Jeffrey
Re: Mac OS X support [message #563599 is a reply to message #11558] |
Hi Jeffery.
Jim
> entry for this:
> Jeffrey
>> Hello,
>> dialog, saying:
>> Reason:
>> permissions on it.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thank you,
>> Jeffrey
Current Time: Sun Sep 07 03:56:57 EDT 2025
Powered by FUDForum. Page generated in 0.04470 seconds
