Re: add Dynamic Data to ComBoboxCellEditor [message #926099 is a reply to message #925719] |
Fri, 28 September 2012 09:52 |
Lorand Lorincz Messages: 35 Registered: April 2011 |
Member |
Hello Sam,
Are you using a simple TreeViewer with only one column or a TreeViewer with multiple columns? I have only worked with multiple column Trees so I can only help you in that direction, but I'm sure you can adapt the multiple column code to the single column TreeViewer.
If you are using multiple columns you must add the editing support to each column. In the place where you build your TreeColumn's do the following.
After creating the TreeColumn, wrap it in a TreeViewerColumn using its constructor. Define a new org.eclipse.jface.viewers.EditingSupport. Then set the editing support using the setter from the TreeViewerColumn.
EditingSupport has 4 main methods which you have to implement like follows:
org.eclipse.jface.viewers.EditingSupport.canEdit(Object) returns true if the cell can be edited, false otherwise.
org.eclipse.jface.viewers.EditingSupport.getCellEditor(Object) returns a new ComBoboxCellEditor in your case, and sets the input of the ComboBox.
org.eclipse.jface.viewers.EditingSupport.getValue(Object), in your case will return the index of the item selected by default in your combo
org.eclipse.jface.viewers.EditingSupport.setValue(Object, Object) saves the selected value to your backend, and calls a refresh on the TreeViewer.
Hope this helps,
Lori
Re: add Dynamic Data to ComBoboxCellEditor [message #926443 is a reply to message #926099] |
Fri, 28 September 2012 17:01 |
Missing name Missing name Messages: 4 Registered: September 2012 |
Hello Lori
Thank you very much for your reply. I have two columns - one which has a String Value and the other column - a ComBoboxCellEditor. Based on the String Value, I have to get the data which has to be filled in ComBobox of the second Column. My code is:
TreeColumn attributeColumn = new TreeColumn(attributeTree, SWT.LEFT);
attributeColumn.setText("Sources Object");
attributeColumn.setWidth(400);
TreeColumn RDNColumn = new TreeColumn(attributeTree, SWT.LEFT);
RDNColumn.setText("RDN");
RDNColumn.setWidth(140);
CheckboxCellEditor attrEditor = new CheckboxCellEditor(attributeTree);
RDNEditor = new ComboBoxViewerCellEditor(attributeTree, SWT.READ_ONLY);
/*ComboBoxEditingSupport combo = new ComboBoxEditingSupport(attributeTree);
combo.createControl(attributeTree);*/
CellEditor[] editors = new CellEditor[] { attrEditor, RDNEditor};
TreeViewerColumn RDNTreeColumn = new TreeViewerColumn(attributesTreeViewer, SWT.NONE);
RDNTreeColumn.setEditingSupport(new EditingSupport(attributesTreeViewer) {
protected boolean canEdit(Object arg0) {
return false;
protected CellEditor getCellEditor(Object arg0) {
return RDNEditor;
protected Object getValue(Object arg0) {
// TODO Auto-generated method stub
return null;
protected void setValue(Object arg0, Object arg1) {
Now the problem is that based on the 'Sources object' TreeColumn value, I have to get the input of the COmbo Box. So, How can I send the data of the 'Sources Object' Tree Column String value into the getCellEditor() function which sets the input of my Combo Box (as per you told).
Can you please help me?
Thank you very very much for your reply.
-Sam
Re: add Dynamic Data to ComBoboxCellEditor [message #926687 is a reply to message #926595] |
Fri, 28 September 2012 22:23 |
Hi Lori
Here is my code:
Class A which creates the TreeViewer
public void createControl(Composite parent) {
Composite composite = new Composite(parent, SWT.NONE);
composite.setLayout(new GridLayout(2, false));
setControl(composite);
Label explanationLabel = new Label(composite, SWT.NONE);
explanationLabel
.setText("Check the source objects that you want to publish to the new Global Profile View:");
GridData explanationLabelData = new GridData();
explanationLabelData.horizontalSpan = 2;
explanationLabel.setLayoutData(explanationLabelData);
attributesTreeViewer = new TreeViewer(composite, SWT.FULL_SELECTION
| SWT.V_SCROLL | SWT.H_SCROLL | SWT.BORDER);
// hack to set a default row height
attributesTreeViewer.getTree().addListener(SWT.MeasureItem,
new Listener()
public void handleEvent(Event event)
event.height = 27;
// end of hack
attributesTreeViewer.setUseHashlookup(true);
attributesTreeViewer.setColumnProperties(COLUMN_PROPERTIES);
Tree attributeTree = attributesTreeViewer.getTree();
GridData attributeTreeData = new GridData(GridData.FILL_BOTH);
attributeTreeData.widthHint = 550;
attributeTreeData.heightHint = 400;
attributeTree.setLayoutData(attributeTreeData);
attributeTree.setHeaderVisible(true);
attributeTree.setLinesVisible(true);
attributesTreeViewer.setAutoExpandLevel(TreeViewer.ALL_LEVELS);
initList(); //This function generates the dynamic data and is
// stored in a Hash Map
attributesTreeViewer.setCellEditors(editors);
.setCellModifier(new AttributesViewerCellModifier());
.setContentProvider(new AttributesTreeViewerContentProvider());
.setLabelProvider(new AttributesTreeViewerLabelProvider());
RDNEditor.setContenProvider(new AttributesTreeViewerContentProvider());//ArrayContentProvider());
RDNEditor.setLabelProvider(new LabelProvider());
Content Provider Class
static class AttributesTreeViewerContentProvider implements
ITreeContentProvider
public Object[] getChildren(Object arg0)
SourceNode node = (SourceNode) arg0;
return node.getChildren().toArray();
public Object getParent(Object arg0)
return node.getParent();
public boolean hasChildren(Object arg0)
return node.hasChildren();
public Object[] getElements(Object arg0)
return getChildren(arg0);
public void dispose()
public void inputChanged(Viewer arg0, Object arg1, Object arg2)
public Object[] getValue(Object arg0)
return node.getRDNValues();
Label Provider Class
static class AttributesTreeViewerLabelProvider extends LabelProvider
implements ITableLabelProvider
public Image getColumnImage(Object arg0, int index)
if (node.isRootNode() && index == 0)
if (node.isSelected())
return ImageStore.getImage(ImageStore.CHECK);
else
return ImageStore.getImage(ImageStore.NOCHECK);
return null;
public String getColumnText(Object arg0, int index)
if (index == 0)
if (node.isRootNode()) {
return node.getSourceObjectName();
else
String dn = node.getSourceDn();
return VdsHelperUtility.extractObjectName(dn) + " ("
+ VdsHelperUtility.extractParentName(dn) + ")";
if (!node.isRootNode() && index == 1)
String rdnVal = node.getSelectedRDNValue();
return rdnVal;
return null;
Another Class which is a CellModifier class implementing ICellModifier
class AttributesViewerCellModifier implements ICellModifier
public boolean canModify(Object element, String property)
if (element instanceof SourceNode)
SourceNode node = (SourceNode) element;
return (property.equals("Sources Object"));
else
return (property.equals("RDN"));
return false;
public Object getValue(Object element, String property)
if(property.equals("RDN")) {
if(node.isRootNode())
return null;
else {
String rdn = node.getSelectedRDNValue();
return rdn;
else
return node.isSelected();
return null;
public void modify(Object element, String property, Object value)
TreeItem treeItem = (TreeItem) element;
SourceNode node = (SourceNode) treeItem.getData();
if (value instanceof String)
String valueStr = (String) value;
if ((valueStr != null) || (valueStr != ""))
node.setSelectedRDNValue(valueStr);
attributesTreeViewer.refresh();
if (property.equals("Sources Object"))
node.setSelected(!node.isSelected());
validatePage();
I need to take the "Sources Object" string value and based on it get the String array from the hashmap (which is derived in initList function) and then add the array into the Combo Box.
SourceNode is the object class. extractParentName() and extractObjectName() are some additional functions which parses the dn.
Thank you very muc again Lori. very much Appreciated.
-Sam
Re: add Dynamic Data to ComBoboxCellEditor [message #927088 is a reply to message #926687] |
Sat, 29 September 2012 08:36 |
Member |
OK, I got the problem. This is a perfect example of why EditingSupport is better then using CellModifiers. Because you use CellModifiers you initialize the CellEditors when you build your Tree.
Using Editing Support you get this new method org.eclipse.jface.viewers.EditingSupport.getCellEditor(Object). This method allows you to hook in and build you CellEditor when the cell is clicked. The element parameter is the element that is returned by the content provider for the edited cell.
Instead of initializing your cellEditors and CellModifiers in the createControl(Composite parent) method you should only define an EditingSupport for each TreeColumnViewer. For example, for the second TreeColumnViewer the Editing suport should look something like this:
attributeColumnViewer.setEditingSupport(new EditingSupport(){
CellEditor getCellEditor(Object element){
CheckboxCellEditor cellEditor = new CheckboxCellEditor(attributeTree);
String[] arr = map.get(element.getObjectName());
cellEditor.setInput(arr);
return cellEditor;
boolean canEdit(Object element){
//the code from your canModify method of the cell modifier
Object getValue(Object element){
// the code from getValue method of the cell modifier
void setValue(Object element){
//the code from modify method of the cell modifier
Practically the EditingSupport replaces what you have done with cell modifiers.
Don't forget, you have to define an EditingSupport for each TreeColumnViewer.
Lori
[Updated on: Sat, 29 September 2012 08:37] Report message to a moderator
FUDForum. Page generated in 0.05975 seconds
