Home » Archived » Visual Editor (VE) » JVM terminated when trying to create java class with Visual Editor
JVM terminated when trying to create java class with Visual Editor [message #125521] Fri, 02 June 2006 16:25 Go to next message
Originally posted by: lovejoy.us.ibm.com
I installed Visual Editor using the instructions at the link
http://www.eclipse.org/vep/WebContent/faq.html#install_howto .
When I try to create a new java class using the Visual Editor I get the
following error:
JVM terminated. Exit code=1
/usr/bin/java
-Xms40m
-Xmx256m
-jar /afs/btv.ibm.com/u3/lovejoy/eclipse/startup.jar
-os linux
-ws gtk
-arch x86
-launcher /afs/btv.ibm.com/u3/lovejoy/eclipse/eclipse
-name Eclipse
-showsplash 600
-exitdata 105000d
-vm /usr/bin/java
-vmargs
-Xms40m
-Xmx256m
What am I doing (did I do) wrong?
Re: JVM terminated when trying to create java class with Visual Editor [message #125536 is a reply to message #125521] Fri, 02 June 2006 16:35 Go to previous messageGo to next message
Originally posted by: jefmyers.us.ibm.com
Steve,
What JRE are you using to run Eclipse? (i.e. what's the output of
/usr/bin/java -version) VE is not compatible with GCJ, if you're using
that, you'll need to install and run with a Sun or IBM JRE instead.
Hope this helps,
- Jeff
Re: JVM terminated when trying to create java class with Visual Editor [message #125590 is a reply to message #125536] Mon, 05 June 2006 08:49 Go to previous messageGo to next message
Output of /usr/bin/java -version
java version "1.4.2"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2)
Classic VM (build 1.4.2, J2RE 1.4.2 IBM build cxia32142-20050929 (SR3)
(JIT enabled: jitc))
Re: JVM terminated when trying to create java class with Visual Editor [message #125604 is a reply to message #125590] Mon, 05 June 2006 11:06 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
I've had problems with the "Classic" vm. Try adding the VM argument -Xj9
(this is case-sensitive. must -Xj9).
Rich Kulp
Re: JVM terminated when trying to create java class with Visual Editor [message #125653 is a reply to message #125604] Mon, 05 June 2006 13:43 Go to previous messageGo to next message
Tried the following command:
eclipse -vm /usr/bin/java -Xj9 -vmargs
Is that the proper command?
I create the visual editor class and then I try to edit it. It briefly
flashed what looked like the proper screen to create/edit the actual java
code and then get:
/usr/bin/java
-os linux
-ws gtk
-arch x86
-name Eclipse
-showsplash 600
-exitdata 119800c
-Xj9
-vm /usr/bin/java
-vmargs
Re: JVM terminated when trying to create java class with Visual Editor [message #125677 is a reply to message #125653] Mon, 05 June 2006 16:22 Go to previous messageGo to next message
It's the other way around.
-vm /usr/bin/java -vmargs -Xj9
> java code and then get:
> /usr/bin/java
> -os linux
> -ws gtk
> -arch x86
> -name Eclipse
> -showsplash 600
> -exitdata 119800c
> -Xj9
> -vm /usr/bin/java
> -vmargs
Rich Kulp
Re: JVM terminated when trying to create java class with Visual Editor [message #125954 is a reply to message #125677] Fri, 09 June 2006 13:45 Go to previous messageGo to next message
Thanks. I tried it again. The Visual editor starts up, goes into Loading
... then hangs. The following error was printed:
/usr/bin/java
-os linux
-ws gtk
-arch x86
-name Eclipse
-showsplash 600
-exitdata 80005
-Xj9
-vm /usr/bin/java
-vmargs
Re: JVM terminated when trying to create java class with Visual Editor [message #125979 is a reply to message #125954] Fri, 09 June 2006 15:36 Go to previous message
I don't know. Can you try Sun's 1.4.2 instead? There is something wrong
the Java.
> Loading ... then hangs. The following error was printed:
> /usr/bin/java
> -os linux
> -ws gtk
> -arch x86
> -name Eclipse
> -showsplash 600
> -exitdata 80005
> -Xj9
> -vm /usr/bin/java
> -vmargs
Rich Kulp
Re: JVM terminated when trying to create java class with Visual Editor [message #613002 is a reply to message #125521] Fri, 02 June 2006 16:35 Go to previous message
Steve,
Hope this helps,
- Jeff
Re: JVM terminated when trying to create java class with Visual Editor [message #613011 is a reply to message #125536] Mon, 05 June 2006 08:49 Go to previous message
Re: JVM terminated when trying to create java class with Visual Editor [message #613013 is a reply to message #125590] Mon, 05 June 2006 11:06 Go to previous message
Rich Kulp
Re: JVM terminated when trying to create java class with Visual Editor [message #613019 is a reply to message #125604] Mon, 05 June 2006 13:43 Go to previous message
code and then get:
/usr/bin/java
-os linux
-ws gtk
-arch x86
-name Eclipse
-showsplash 600
-exitdata 119800c
-Xj9
-vm /usr/bin/java
-vmargs
Re: JVM terminated when trying to create java class with Visual Editor [message #613021 is a reply to message #125653] Mon, 05 June 2006 16:22 Go to previous message
> /usr/bin/java
> -os linux
> -ws gtk
> -arch x86
> -name Eclipse
> -showsplash 600
> -exitdata 119800c
> -Xj9
> -vm /usr/bin/java
> -vmargs
Rich Kulp
Re: JVM terminated when trying to create java class with Visual Editor [message #613328 is a reply to message #125677] Fri, 09 June 2006 13:45 Go to previous message
/usr/bin/java
-os linux
-ws gtk
-arch x86
-name Eclipse
-showsplash 600
-exitdata 80005
-Xj9
-vm /usr/bin/java
-vmargs
Re: JVM terminated when trying to create java class with Visual Editor [message #613330 is a reply to message #125954] Fri, 09 June 2006 15:36 Go to previous message
the Java.
> /usr/bin/java
> -os linux
> -ws gtk
> -arch x86
> -name Eclipse
> -showsplash 600
> -exitdata 80005
> -Xj9
> -vm /usr/bin/java
> -vmargs
Rich Kulp
Previous Topic:Anybody is extending VE to create their own IDE?
Next Topic:Can I use VE to make RCP applications for Eclipse?
Current Time: Thu Nov 06 12:36:17 EST 2025
Powered by FUDForum. Page generated in 0.05282 seconds
