Home » Archived » BIRT » export report to image (i.e. png)
export report to image (i.e. png) [message #125135] Tue, 07 February 2006 04:42 Go to next message
Originally posted by: kctang.gmail.com
Can someone show me how to easily export a report design to image files
(i.e. png) using the "Report Engine API". I've used such a feature in
JasperReports where every page in a report can be exported as an image.
FYI, I only managed to use "Report Engine API" to generate reports in both
HTML and PDF formats... also after a bit of stumbling around.
Any help is greatly appreciated! ;-)
Re: export report to image (i.e. png) [message #1030657 is a reply to message #125135] Sun, 31 March 2013 10:33 Go to previous message
Did you find any solution for this ? I am also looking for some method to export BIRT report to image.
Your help is really appreciable.
Previous Topic:Stored procedure data retrieval used in multiple charts
Next Topic:Install and use birt with lotus domino xpages web application
Current Time: Fri Sep 19 18:04:22 EDT 2025
Powered by FUDForum. Page generated in 0.03497 seconds
