Infer EReference from a CompartmentEditPart [message #923887] |
Wed, 26 September 2012 05:26  |
Hi all,
i'm wondering if it is possible to infer the corresponding EReference in the semantic model from a CompartmentEditPart in the notational model.
I know how to retrieve the EObject the CompartmentEditPart refers to, but is it also possible to get the EReference that is used to store the child objects?
Re: Infer EReference from a CompartmentEditPart [message #940028 is a reply to message #939175] |
Thu, 11 October 2012 04:45  |
Thomas,
I doubt it is possible to get access to the meta-information at the diagram runtime.
(Also there may be a lot of the different children types associated with same compartment, so it is more correct to tell about the List<EReference> instead of just EReference).
However, if you are using GMF-Tooling, you may add custom template to generate into every XXComartmentEditPart a new method that will provide access to this meta-, and then use it at runtime in your custom code.
Please let me know if you need more help with that way of solving the problem.
Michael
FUDForum. Page generated in 0.04141 seconds
